B18CR, Toda, Skunk2, 4.7ratio, 92 SI
Old Jan 23, 2004 | 11:58 AM
asubennett's Avatar
Default B18CR, Toda, Skunk2, 4.7ratio, 92 SI
THis was posted a long time ago- was goign to keep it but now something else has my love. I test drove an STI- that is where I am heading. Use this sale as down payment on the Subby. Anyway on to the car-
1992 Si hatch
JDM ITR swap done by Autolinks Motor works
Hasport mounts all the way around
JDM 4-1 header, straight pipe and 2.5 carsound if you want it
2.5 polished RSR Invidia cat back (no longer make) very sought after
Mugen head gasket
3 angle Valve Job
Skunk2 nitrided valves
bronze valve guides
new valve seals
skunk2 valve springs
Titanium retainers
Toda Spec C camshafts
Toda Timing belt
AEM cam gears
Aeormotive fuel pressure regulator
Walbro fuel pump
stainless steel fuel lines
3 inch intake
port matched intake manifold
ericks racing 70-68 mm throttle body
RC engineering 310cc injectors
Skunk2 P28
Vafc
JDM 4.7 ITR tranny
ACT clutch and ACT heavy duty pressure plat
resurfaced ITR flywheel
four wheel disc brakes
Tokico Blues shocks and springs
front and rear stabilizer bars
Autopro harnesses and harness bar
Autocross buckets
Great compression in motor
Always ran on Mobil one oil and honda MTF and Honda oil filter
This car absolutely rips and will make someone very happy with it's reliability and fun factor. I will hate to see it go. Need to get riud of very soon so I can put money down on the Sti. looking for $9,500. Thanks guys. Jason
Old Jan 23, 2004 | 03:13 PM
Prelusion98's Avatar
Default Re: B18CR, Toda, Skunk2, 4.7ratio, 92 SI (asubennett)
Sounds nice. However, I would recommend a picture or two. You would be amazed at how many more hits you'll get. Another recommendation: try autotrader.com or the Recycler. This place doesn't seem to be all that successful.
Old Jan 24, 2004 | 10:31 PM
asubennett's Avatar
Default Re: B18CR, Toda, Skunk2, 4.7ratio, 92 SI (Prelusion98)
there is pics from a previous thread I will try and dig up a link for it. And your right about unsuccesful on these boards but any exposure is good exposure i suppose. But mostly get dreamers on this board.
EGD
Nov 13, 2007 03:55 PM
asubennett
Apr 15, 2004 04:38 PM
jeremy.
13
Jan 2, 2004 01:13 AM
asubennett
Dec 3, 2003 11:58 AM
Chugger
Jul 13, 2003 11:09 AM
