valve cover gasket and parts install
ok just picked up all the parts i needed from honda. i got a valve cover gasket, 8 washers, 8 nuts, 5 long bolts, 3 short bolts, 4 spark plug seals, and hondabond. now im going to install these tomorrow and i was wondering a few things...
1. what am i supposed to torque the double sided bolts that go into the head down to? and do i need to use loctite or something?
2.do i need to use hondabond on the valve cover gasket, spark plug seals, and valve cover washers?
3. when torquing down the nuts on top i know im supposed to do 8ft/lbs, but is there a specific pattern im supposed to follow?
thanks guys!
thanks guys!
I changed my valve cover and gasket I think the top bolts I did 8ft/lbs I didn't use any seals on the valve cover seals and the spark plug ones...but that might have been a bad thing....
My valve cover is fine though....no leaks no nothing I did use some silicon gasket grab for the valve cover gasket, just because I don't want no leaks or anything.
Good luck, it's a pretty easy job and if you have a friend to help you out, you can do it much quicker.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shakes »</TD></TR><TR><TD CLASS="quote">you need a helm manual</TD></TR></TABLE>
i know but i wont be able to get one in time... i just need to know those torque specs on those bolts that go into the head
PearlWhiteAccord
Jan 8, 2004 01:13 PM
