close ratio for y2 gear box
Old Jan 23, 2004 | 10:04 AM
gilou bilou's Avatar
Default close ratio for y2 gear box
Hello,
I have a civic 4g ee9 1991 (european market) same to ef9 or sir jdm.
the motor as an b16a1 and gearbox are y2 but the clutch move wive cable.
I want to found a short final drive because mine is 4.133 and is so long. But i dont found for cable tranny. It is possible to put an hydro final drive on a cable tranny or where is possible to found a close final drive for cable tranny.
Please help me !
sorry for my english, i'm french !
Old Jan 23, 2004 | 10:53 PM
YumVTEC's Avatar
Default Re: close ratio for y2 gear box (gilou bilou)
i believe I've read that you can use a hydro final drive in a cable tranny, but you have to use the hydro tranny differential as well. i could be mistaken. i've something on this subject here on h-t though.
Old Jan 23, 2004 | 11:38 PM
irev210's Avatar
Default Re: close ratio for y2 gear box (YumVTEC)
yah its pretty hard to do..
The Y2 isnt a bad tranny, has a shorter first gear then the Y1
Did they offer Factory LSD on the Y2 gear box?
Old Jan 24, 2004 | 01:15 AM
Default Re: close ratio for y2 gear box (irev210)
Thanks,
Yes, in fact i want to use an hydro final drive into my cable tranny.
Some spec of my gearbox:
Y2 with cable
1st:3.25
2nd:2.052
3nd:1.416
4nd:1.103
5nd:0.87
FD:4.133 so long ...
No LSD ...
And, when i see the spec of the us gearbox, i dont found any similar gearbox ....
Because i'm very interesting to know if is possible to put an ITR final drive (4.785) on my gearbox ... because a short final drive for cable cost 1250$ and an ITR 400$
I prefere to put an ITR final drive and the LSD for the same cost ....
Old Jan 12, 2015 | 03:07 PM
gabrielsousa's Avatar
Originally Posted by gilou bilou
Thanks,
Y2 with cable
1st:3.25
2nd:2.052
3nd:1.416
4nd:1.103
5nd:0.87
No LSD ...
thanks for the info
SIXTY
Nov 3, 2008 01:41 PM
CRXEE8
Jun 19, 2005 01:32 AM
gilou bilou
12
Jan 24, 2005 12:37 PM
