How do I get the Door latch out?
My driver's side door won't close because the latch is stuck. How do I get the latch out to replace it or take a look at it and possible fix it? The only problem I'm having getting it out is the lock & handle rods..how do i get dem off the latch?!?!
its easier to do if you actually pull the window out. that way you have room to turn the rods every which direction. you need to take the rods off the little actuator lever first though before you can take them off the latch.
B20inDCinLBC
13
Apr 21, 2009 10:28 AM
