a thought
i dont wanna spend another 150 on steering knucks so i had a thought im not sure if its doable thats where u guys come in.
im thinkin of tryin to hybrid my old hf steering knuckle. i wanna take the old knuckle and have 90 teg hubs and wheels bearing put in. will the hf knuckle accept the hub and bearings?
if the outside diameter is the same between hf and teg bearings it should work . you may have to still use the smaller brakes though . or make a bracket to fit the bigger brakes on. i thought about using the typeR 5 lug hub and getting a disc to fit it and run typeR wheels but i put the money in my motor
