Does anyone know how to convert a 4 wire oxy.sensor into a 1 wire?
Old Jan 22, 2004 | 06:55 PM
I Gotta Question's Avatar
Default Nevermind I searched w/ O2 intead of Oxygen sensor, sorry for the trouble
https://honda-tech.com/zerothread?id=721982
Modified by I Gotta Question at 8:48 PM 1/22/2004
Old Jan 22, 2004 | 07:14 PM
Default Re: Does anyone know how to convert a 4 wire oxy.sensor into a 1 wire? (I Gotta Question)
Old Jan 22, 2004 | 07:15 PM
ITSTOCK's Avatar
Go to parts store, buy a 4 wire o2 sensor. That is your only option.
Old Jan 22, 2004 | 07:31 PM
Default Re: Does anyone know how to convert a 4 wire oxy.sensor into a 1 wire? (ITSTOCK)
Old Jan 22, 2004 | 07:35 PM
Built B16A's Avatar
From: hittin corners so hard you can taste my rims..
Just a thought.. this is the EF/Civic Forum. Pre 92' Vehicals.
The 4 wire O2, and your question is OBD1 related, Since OBD1 starting in 92, i would think your post would be more benificial in the EG / 92' and up forums...
Just a thought.
Old Jan 22, 2004 | 07:44 PM
Default Re: Does anyone know how to convert a 4 wire oxy.sensor into a 1 wire? (Built B16A)
Old Jan 22, 2004 | 07:51 PM
ITSTOCK's Avatar
Ok, your question was different then what you were looking for, your wondering how to use a 4 wire o2 sensor on a obd - 0 car right? i thought u meant using a one wire on a obd-1. That diagram you put up shows how to manually wire up a 4 wire o2 sensor on a obd-1 car.
Old Jan 22, 2004 | 07:57 PM
Built B16A's Avatar
H-T's search can be your best friend.
Old Jan 22, 2004 | 08:30 PM
biggdogg's Avatar
Default Re: Nevermind I searched w/ O2 intead of Oxygen sensor, sorry for the trouble (I Gotta Question)
http://ludicrous2_0.tripod.com/how_to/oxy/
try this ,it worked in my car.
Old Jan 22, 2004 | 08:34 PM
yeah but you can just use that diagram to fig out how to wire a one wire into a 4 wire harness.
sorry if you cant fig. it out you connect the blacks together and the white connects to the one wire on the OBD0 O2 sensor and the green you dont need just leave it.
Modified by I Gotta Question at 9:49 PM 1/22/2004
Old Jan 22, 2004 | 08:50 PM
wow you really are a moron I thought those people were just talkin crap, but I guess they were right....hmmph go figure.
Old Jan 23, 2004 | 08:19 PM
https://honda-tech.com/zerothread?id=743973
I went through the trouble of making instructions to eliminate that hoe altogether.
nharper12
Feb 22, 2014 10:22 AM
pedroa06
11
Feb 8, 2010 06:22 PM
hmtcrxsir
Jul 2, 2007 06:56 PM
FBPninetynineEM1
Nov 17, 2003 04:30 PM
