weird stuff
put a zc tranny in this week. got it back on the road today and took a ride. all is well except for the steering. car goes str8 until i hit a bump. if i hit a bump wit lf tire the car pulls left, if i hit bump wit rf tire the car pulls right. im thinking toe issue possibly. im usin 90 teg knuckles. also the steering as a whole is extremly easy to turn from what it used to be. hope some1 can steer me in the right direction. thanks in advance
Make sure your suspension isn't kicked loose, and you didn't forget to attatch something... like possibly a couple of bad castle nuts... loose control arm.
if the steering effort got alot easier, your castor angle may be out; if this
is the case, I can only surmise that it is due to either incompatible components
or components installed incorrectly, as I don't believe that this
is an adjustable setting.
good luck
good luck
