where can i get an lsd
just a tranny, i'm not sure
but i know you can get engines
w/lsd tranny from http://www.hmotorsonline.com
The type S tranny is the same one that is in the 5th gen SH here in the US. If you want an OEM LSD tranny from an S-spec then you can check hmotors. The 4th gen LSD tranny code is M2B4. You can't drop the differential from these trannys into your USDM housing, it is too big.
HTH,
HTH,
Correct. The OEM LSD in the M2B4 is to big to fit in the USDM housing. People have tried it (SatanSRV I think) and proven it not to work. I have heard rumors of people modifing the ITR LSD to fit but I have no idea how.
You are best just getting the entire tranny or a Quaife.
Knightzero7
Transmission & Drivetrain
Apr 10, 2014 02:39 PM
