Intake hose
Out of curiosity, i was wondering what the smaller of the two hoses that go to the intake tube in a '93? I saw a picture of someone's engine on cardomain and he did not have it hooked up, is it not necessary?
im drawing a blank.....on 5th gen ex's, one is for the vtec, the other is for.....i dont remember, but its not neccesary as long as theres some kinda filter on it.....im assuming 4th gens are the same
im assuming ur intake hose can only take one hose......use the one off the valve cover, im 90% sure thats for the vtec, but im NOT positive (trying to remember the schematic diagrams from my AEM instal)......the second one is fine, just make sure u put a piece of foam or a breahter filter on it
no, the intake hose has a thing for both of them, it's not really a problem just a matter of curiosity of what the small one is for. And yeah i always thought that big one was the vtec.
Modified by n0strax at 4:46 AM 1/23/2004
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by n0strax »</TD></TR><TR><TD CLASS="quote">the larger of the two goes to the top of the valve cover and the smaller one went across a little to a little container thing that says "Up" </TD></TR></TABLE>
the larger one is your crank case ventilator...this is the one that goes from your valve cover to the intake tube...the other one connected to that same hose is the egr vaccuum line...the little can that says up is your egr, not vtec selenoid or anything of that sort...
also, i wouldn't recomend you put a breather on the crank case ventilator unless you are runnig forced induction...there's a reason honda plummed that back into the intake...
so is it safe for that smaller hose to jsut be sitting there taking in the little bit of air it does or should i rubber band a sock over it to keep some dirt out until i get a hose that fits?
CIVICNONVTEC
Jul 21, 2003 06:41 PM
