Small crack on the transmission Housing
i cracked my transmission a few months ago, a small crack at that but it leaks fluids. Tranny is fine performance wise. I really do not want to replace it right now as I'm strapped for cash. Is welding an option?
Thanx Greg
Modified by gliaw at 10:54 PM 1/23/2004
Thanx Greg
I had mine aluminum welded once I broke it down for a rebuild. The previous owner had JB welded it. The JB weld worked, but I wanted a more permanant seal.
It's better to weld it with the case apart, that way you can drill the ends of the cracks out from the inside, then weld it from both sides.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG Civic »</TD></TR><TR><TD CLASS="quote">sorry to jump off the topic..but jb weld isn't permenant?</TD></TR></TABLE>
those are like super glue for car
they work great, dont get me work
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG Civic »</TD></TR><TR><TD CLASS="quote">sorry to jump off the topic..but jb weld isn't permenant?</TD></TR></TABLE>Yeah it is permanent, but it's a cheap and unsightly fix if you ask me. A true weld is 100 times better.
LeonardDB
Sep 13, 2005 12:06 PM
