problem after dpfi-mpfi swap
Old Jan 22, 2004 | 10:01 AM
mugenwannabe's Avatar
Default problem after dpfi-mpfi swap
had a d15b2 in a crx and put a d16a6 in it. now i am throwing a code 4, idle is at 2100 and i get fuel cut at 3200. has anyone had this similar problem? what was the solution?
Old Jan 22, 2004 | 11:17 AM
Big Bang's Avatar
Default Re: problem after dpfi-mpfi swap (mugenwannabe)
It's the angle sensor in the dizzy. Either you have a bad dizzy or you made some mistakes with the wires.
Old Jan 22, 2004 | 12:52 PM
kranked91dx's Avatar
Default Re: problem after dpfi-mpfi swap (The Converted)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The Converted &raquo;</TD></TR><TR><TD CLASS="quote">It's the angle sensor in the dizzy. Either you have a bad dizzy or you made some mistakes with the wires.</TD></TR></TABLE>
Dead on man !
check wiring of the dizzy,
you scewed some wiring, no biggies
don't forget to reset the ECU after you've done some change
PnkRokCountryboy
12
Sep 12, 2007 03:33 PM
drinks2k
May 10, 2007 10:15 PM
crexer
42
Jan 17, 2006 10:24 PM
91tegrals
Nov 28, 2005 08:41 PM
bigblu333
Jan 5, 2004 03:48 PM
