Idle problems when I advanced cam timing
Old Oct 2, 2001 | 05:28 PM
Silude93's Avatar
New User
Default Idle problems when I advanced cam timing
Just wanted to know if anybody else has had problems with their idle when they advanced their intake cam (4 degrees). I love the top-end but I don't want to sacrifice a good idle. Any input would be appreciated.
BTW I have a 93 Si with headwork and web- cams.
Old Oct 2, 2001 | 06:42 PM
97PreludeSH's Avatar
New User
Default Re: Idle problems when I advanced cam timing (Silude93)
When you have headwork and performance Cams. It will make your idle funny. cause the cam profiles are Lopey. Theres nothing you can do about that, you sacrifice a good idle for the performance. Ever heard a built domestic idle? Their idle sucks but their power is amazing!!!
Old Oct 3, 2001 | 06:40 AM
LudeBehavior's Avatar
New User
Default Re: Idle problems when I advanced cam timing (97PreludeSH)
I advanced my cams +2-4 and I sacrificed lots of low end torque but hte pull at 80 and up is worth it.. I had rough idle till I got some nology wires and a header..
If ya wanna jack up your idle it just takes fives sedconds.. Adjust the throttle body cable just tighten or loosen it.. I normally tighten mine up on race day.
Old Oct 3, 2001 | 07:09 PM
Islander9407's Avatar
New User
Default Re: Idle problems when I advanced cam timing (LudeBehavior)
Does the +2 -4 mean you advanced your exhaust cam and retarded your intake or is it the other way around?
[Modified by Islander9407, 4:10 AM 10/4/2001]
haulinhonda
Mar 11, 2013 02:11 AM
GSR_96814
Sep 19, 2006 01:44 PM
matix
Sep 6, 2005 09:10 AM
dubman410
Apr 27, 2005 04:10 AM
94civicx
Jan 1, 2002 09:26 AM
