Honda S2000 Honda S2000
s2000 tranny/clutch
Old Jan 21, 2004 | 06:39 PM
Mr_Red_S's Avatar
Default s2000 tranny/clutch
I bought a 00' S2000. The syncronizer is going bad, gear grinds going from first to second, the clutch is slipping, and its ticking me off. I need help. What should i do. I was thinking new flywheel, new clutch, new PP, and what else do i need to fix. Thanks.
Old Jan 21, 2004 | 07:24 PM
Razor's Avatar
Default Re: s2000 tranny/clutch (Mr_Red_S)
there was a TSB on this . if you got extended warranty, head on over to the dealership and let them take care of it for you.
Old Jan 21, 2004 | 07:26 PM
Mr_Red_S's Avatar
Default Re: s2000 tranny/clutch (Razor)
i bought it used and i don't think it had the extended warranty.
Mr_Red_S's Avatar
how would i go about finding if it has the extended warranty
Old Jan 21, 2004 | 07:29 PM
Razor's Avatar
the person who u bought it from would've most likely mentioned it to you.
Mr_Red_S's Avatar
nope. so am i screwed or what should i do.
Old Jan 22, 2004 | 07:57 AM
KYS2000's Avatar
Try changing the tranny fluid to pennzoil syncromesh same stuff as GM syncromesh, little notchy when its cold but when tranny warms up it should help with the 2nd gear grind.
Old Jan 22, 2004 | 07:31 PM
Mr_Red_S's Avatar
Default Re: s2000 tranny/clutch (KYS2000)
Should i just buy A NEW CLUTCH and pressure plATE. tHE MONEY DOESN'T mATTER.
keviinbraah017
Honda S2000
12
Jan 9, 2012 05:52 PM
IBriaIN
Sep 23, 2008 09:01 AM
reeder321
12
Dec 31, 2003 07:29 AM
DX187VTEC
Jan 31, 2003 12:28 AM
phatintegra
Mar 20, 2002 05:56 AM
