Best bang for buck: rear or front sway bar?
Old Jan 21, 2004 | 06:34 PM
MikeyDB7's Avatar
Default Best bang for buck: rear or front sway bar?
Ok guys.. in your opinion.. can I just go with a rear anti-Sway bar?
I have heard that a front sway bar doesn't do much and that a front tower bar will suffice.
I read in a few threads that a rear sway bar gives the most noticeable improvement in handling..
so my question.. .can I just go with a rear sway bar and ignore the front? or should I just go with a full setup?
thanks ..btw its for a 94 integra sedan
Old Jan 21, 2004 | 06:38 PM
VTECorona's Avatar
Default Re: Best bang for buck: rear or front sway bar? (MikeyDB7)
rear, get the itr rear sway bar with beaks kit.
Old Jan 21, 2004 | 06:41 PM
GSRrR's Avatar
itr bar with bsq's mounting kit. search for his username on here. best suspension bang-for-the buck. really easy to install too.
Old Jan 21, 2004 | 06:42 PM
Chris1091's Avatar
Default Re: Best bang for buck: rear or front sway bar? (GSRrR)
http://www.geocities.com/bretq/
I've been running the BSQ kit for well over a year and no problems what-so-ever!
Old Jan 21, 2004 | 06:49 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
You already have a front swaybar. If your car is an LS it's 22mm, if it's a GS-R it's 24 (unless maybe the sedans all had 24mm in front in 94, not sure).
The ITR 22mm rear swaybar is a great mod.
However swaybars and shock tower bars (and tie bars) do ENTIRELY different things. Swaybars attach to the suspension arms on both sides and resist bodyroll by resisting the suspension wanting to twist the bar. Shock tower bars and tie bars merely only tie chassis points together, making the chassis more rigid. It's more of a "passive" suspension mod while a swaybar is more of an "active" mod, as are shocks and springs.
Old Jan 21, 2004 | 06:53 PM
Toda Built's Avatar
Default Re: Best bang for buck: rear or front sway bar? (PatrickGSR94)
I agree, I would say the ITR rear sway... best bang for buck hands down
Old Jan 21, 2004 | 07:18 PM
b18c1995's Avatar
you could also go with suspension techniques rear sway/tie bar combo. Comptech also make the same thing, but its more expensive.
Old Jan 21, 2004 | 07:34 PM
VTECorona's Avatar
Default Re: (b18c1995)
Alas, the ITR sway bar with beaks\bsq is the best bang for the buck. [/THREAD]
Old Jan 21, 2004 | 08:02 PM
b18jdmteg's Avatar
i would say go with the st kit it's the best bang for your buck in my opinion
Old Jan 21, 2004 | 08:05 PM
thaiphob's Avatar
Nikon!!!
Default Re: Best bang for buck: rear or front sway bar? (b18jdmteg)
the ITR rear sway + beaks or BSQ kit is more cost effective for the paycheck tuner
Old Jan 21, 2004 | 08:11 PM
VTECorona's Avatar
I don't think anything is going to beat the $60 or whatever the ITR sway costs.
Old Jan 21, 2004 | 08:39 PM
iam7head's Avatar
Default Re: Best bang for buck: rear or front sway bar? (VTECorona)
Underpowah FWD car= rear bar
Old Jan 21, 2004 | 10:09 PM
RedGSR's Avatar
If you autox a lot or really into cornering, you should consider the comptech swaybar + tie bar combo. There has been subframe tearing reported for ITR sway bar with (beaks or BSQ - don't remember which). The non - R subframe is just too weak for that kind of torture.
Old Jan 21, 2004 | 10:25 PM
jDMJeRk's Avatar
Default Re: (RedGSR)
I want a front and rear sway bar for my 90-93 teg and i cant find one
Old Jan 21, 2004 | 10:29 PM
GSRrR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RedGSR &raquo;</TD></TR><TR><TD CLASS="quote">If you autox a lot or really into cornering, you should consider the comptech swaybar + tie bar combo. There has been subframe tearing reported for ITR sway bar with (beaks or BSQ - don't remember which). The non - R subframe is just too weak for that kind of torture.</TD></TR></TABLE>
the comptech is great and i would get it if it wasn't that expensive. the tearout was with the beaks kits on a EK. i do not know of any tearouts on the DC. Some thinks that the EK frame might be weaker or maybe its just different geometry.
since i already had a lower tie bar, i just the the itr sway. can not beat it for around 100 with all the parts. only certain tie bar will fit with the larger sway though.
Old Jan 21, 2004 | 11:07 PM
MikeyDB7's Avatar
Default Re: (GSRrR)
thanks for the info guys..
it really helped out
as far as the beaks/BSQ bars and the tearing of frame situation..can any elaborate on this? is this happening on only a few cars? or is it a common flaw with this kit?
Old Jan 21, 2004 | 11:22 PM
GSRrR's Avatar
Default Re: (MikeyDB7)
beaks kit or BSQ kit are just reinforcement kits that allow you to safely install a itr 22mm rear sway bar.
they are needed because a tearout is almost guaranteed to occur if you do not have the reinforcement kits. i have never seen/heard of a tearout with either kit on 3rd gen integras. I use the BSQ because it was cheaper.
BSQ http://www.geocities.com/bretq....html
Beaks http://www.beaksproducts.com/srk-eg.html
mish__
Suspension & Brakes
May 27, 2011 09:08 PM
Jdmls
Jun 8, 2007 11:57 AM
RICHJ
Dec 18, 2002 01:49 AM
Mr.Rab
Sep 27, 2002 12:18 PM
