B16 swap>90 CRX HF
Old Jan 21, 2004 | 05:45 PM
1990crxhf's Avatar
Default B16 swap>90 CRX HF
I am trying to find some information on what all (exactly) will be needed besides engine, trans, and mount kit to complete my swap. I have heard that the HF model is one of the easier swaps because it already has the same type fuel injection, pump, injector connectors, etc. Any help in this area would be greatly appreciated.
Old Jan 21, 2004 | 06:19 PM
jlicrx's Avatar
Default Re: B16 swap>90 CRX HF (1990crxhf)
you will need to swap the knuckles/hubs with ones from 88-91 Civic/CRX DX or Si - 90-93 integra axles - shift linkage - ECU - wiring subharness from Hasport for VTEC
Old Jan 22, 2004 | 09:15 PM
1990crxhf's Avatar
Default Re: B16 swap>90 CRX HF (jlicrx)
thank you very much for the info, I had no clue about the hub assemblies. I had read some about the shift linkage but wasn't sure which axles were needed, was going to drop big bucks on some at hybridgarage.com.
Old Jan 22, 2004 | 09:37 PM
DC 2's Avatar
Here ya go . . . all b16 install links
http://b16a.honda-perf.org/theswap.html
http://www.geocities.com/chipman_13/clippings.html
https://honda-tech.com/zerothread?id=187736
http://www.hasport.com/News/Ar...s.htm
http://www.phatwhippincrx.20m.com/custom.html
Old Jan 22, 2004 | 10:44 PM
91b16acrx's Avatar
Default Re: B16 swap>90 CRX HF (EH3B18B)
ok i ave a 91 hf w/ 16
my friends use 92 integra hubs in the front with 92 integra axles, banged out a lil part of the engine bay to clear the alternator, used spark racing mounts,lol i dont knnow the other specifics
Old Jan 26, 2004 | 10:40 AM
1990crxhf's Avatar
Default Re: B16 swap>90 CRX HF (91b16acrx)
Thank you all for your input. I think I have decided to just go with a ZC and not have to change much. It will still be a large improvement over the HF engine.
Old Jan 26, 2004 | 10:58 AM
tpr's Avatar
tpr
I have had a ZC for 2 years and love it. Put some money into the suspension, sway bars, shocks, bushings and be able to use that additional power in the turns.
Old Jan 26, 2004 | 11:24 AM
KoRE's Avatar
Default Re: B16 swap>90 CRX HF (tpr)
Yes definately bang it out for the alternator or else it won't fit or when the motor moves it'll hit the frame rail...
just bang out the frame rail a bit and you'll be fine...
you don't need the hasport harness just do it yourself or i think another company offers the harness for 150
Old Jan 26, 2004 | 11:42 AM
Rywire's Avatar
Default Re: B16 swap>90 CRX HF (KoRE)
Dont forget mine http://www.geocities.com/droppedcrxsi
Ryan
Old Jan 26, 2004 | 06:11 PM
ls_vtec_crx's Avatar
Default Re: B16 swap>90 CRX HF (droppedcrxsi)
i get one 90 hf wit b16...i used place racing mounts and i never pound out the side wall thing and he no hit...nah but no matter,...you not doin the swap anyways
Old Jan 26, 2004 | 07:25 PM
thrty8street's Avatar
Default Re: B16 swap>90 CRX HF (ls_vtec_crx)
i thought that you had to convert to SI first and then you can swap.???
Old Jan 26, 2004 | 08:22 PM
jlicrx's Avatar
Default Re: B16 swap>90 CRX HF (thrty8street)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thrty8street &raquo;</TD></TR><TR><TD CLASS="quote">i thought that you had to convert to SI first and then you can swap.???</TD></TR></TABLE>
only if you have a DX - HF is already MPFI
Old Jan 26, 2004 | 08:53 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlicrx &raquo;</TD></TR><TR><TD CLASS="quote">
only if you have a DX - HF is already MPFI</TD></TR></TABLE>
ohhhh and what is MPFI again?
Old Jan 26, 2004 | 09:12 PM
chadmasterc's Avatar
multi point fuel injection you f*ck.
civicdust
May 2, 2005 09:11 PM
91B16HF
Mar 14, 2005 06:52 AM
Project_ED8
Jan 9, 2004 09:11 AM
mstrymxer
Sep 23, 2003 12:36 PM
pirocrxracer
Sep 11, 2003 06:19 AM
