don't know which to go with. carb or FI
Old Jan 21, 2004 | 02:16 PM
LillDragun's Avatar
Default don't know which to go with. carb or FI
i'm lookin into getting a bike and i've been told to get a bike that is FI and i've also been encouraged to go the carb route. i was told by some people that the carb route is cheaper and simpler in terms of maitenance and the FI was a more complicated and more expensive if anything goes wrong, i was also told that i should go the carb route since FI is reletively new to bikes. then i have also heard the opposite of what i just said. i was looking into getting a 99 or 00 cbr f4 or f4i and those are the last carb motors. any suggestions and can ya'll clear this up on which is better or which i should get as a beginner rider?
Old Jan 21, 2004 | 06:35 PM
tonydatyga's Avatar
Default Re: don't know which to go with. carb or FI (LillDragun)
you won't have any trouble w/ the f4i FI setup. That said, you won't have any problems w/ an f4 either other than your usual carb problems. Dry storage would be the number one factor. If you're a 9 month rider than f4i may be easier for you storage wise. Other than that price would be my number 1 factor. Cost of the bike and the difference between a pcIII and a jet kit/dyno time.
Old Jan 21, 2004 | 11:27 PM
LillDragun's Avatar
Default Re: don't know which to go with. carb or FI (tonydatyga)
what kind of carb problems are the "usual" problems?
Old Jan 22, 2004 | 01:59 AM
busa1300's Avatar
Carbs tend to gum up or more accurately the gas tends to gum up in storage and with a carbed bike it can partly or totally plug some of the jets and or faces in the carbs. In a fuel injected bike it may partly block some of the injector nozzles but with some injector cleaner will eliminate that. Plus injected bikes compensate for altitude changes.
Discosteak
Honda Motorcycles
Mar 27, 2009 02:52 PM
OC Geezer
Honda Motorcycles
18
Oct 5, 2008 09:38 AM
turbotuner20v
Honda Motorcycles
18
Jul 20, 2005 02:57 PM
veXati0n
Honda Motorcycles
39
Mar 27, 2003 06:24 PM
veXati0n
Honda Motorcycles
Mar 3, 2003 07:35 AM
