Use cruise control switch as fog light switch?
Old Jan 21, 2004 | 11:36 AM
Project X's Avatar
Default Use cruise control switch as fog light switch?
Is it possible to wire up the cruise control switch as a fog light switch?
I really don't want to spend $200 on the JDM fog light switch.
Old Jan 21, 2004 | 11:47 AM
One Bad GeeSeeR's Avatar
Default Re: Use cruise control switch as fog light switch? (Project X)
does it really cost 200 dollars? i would think you can use the cruise button. bust out a multimeter. and figure out the wires.
Carlo
Old Jan 21, 2004 | 12:57 PM
BolivianDc2's Avatar
Default Re: Use cruise control switch as fog light switch? (One Bad GeeSeeR)
yes u can, green is power out, black is ground
ill post more info later, got class
Old Jan 21, 2004 | 01:27 PM
sys3rror's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Project X &raquo;</TD></TR><TR><TD CLASS="quote">Is it possible to wire up the cruise control switch as a fog light switch?
who ever charges $200 for a JDM fog light switch is smoking some crazy ish.
you can get it for $45-$50 shipped with the pig tail connected. contact brian at b18c1_powered_si on this board and he'll hook you up.
Old Jan 21, 2004 | 01:45 PM
BigLoadChoakHard's Avatar
i think thats a pretty trick idea anyway
Old Jan 21, 2004 | 02:30 PM
Default Re: (BigLoadChoakHard)
If you ever take apart a US cruise contrl button and a JDM fog light switch, the basic difference is the 3 mm face that has a little picture of a fog light. Somebody did the write up on team-integra.net here http://www.team-integra.net/se...h=fog
do everything he says to do, except if you going to use a cruise button here are what the wires do:
Light Green = Power Out
Black = Ground
(gotta double check this next one)
Black w/ yellow stripe = power in
Old Jan 22, 2004 | 06:51 PM
bitzbp's Avatar
Default Re: (Bolivianstrtwpn)
I recently wired the fog lights on my JDM front to the cruise control button. Its real easy, but make sure you use a relay, I shouldn't have to say that but just in case....
Old Jan 22, 2004 | 07:23 PM
[ iLL ] iNt3GrA's Avatar
i got my jdm fog switch free w/ the fogs
Old Jan 22, 2004 | 08:44 PM
Default Re: (bitzbp)
i wonder does anyone have pics of the symbol of the fog light i want to make my own. so i can replace the 3mm cruise symbol with the fog light symbol
Carlo
Dat1BVtecN
May 16, 2007 04:40 PM
HONDACURA-DB8
Oct 10, 2006 11:59 PM
GranadaTeg
Jan 16, 2006 08:52 PM
al_r
Oct 18, 2003 07:28 AM
