Currently Modifing a 1985 carbuerated CRX...
Old Jan 21, 2004 | 09:56 AM
95turbohatch's Avatar
Default Currently Modifing a 1985 carbuerated CRX...
Whats up Honda Tech..
I have a 1985 crx carbuerated.. lol
I am in the process of building a d15b turob to drop in ..
I know i have to convert to fuel injected... How hard is that and does anyone have any quick webpages that i can look on for the conversion.. i have been lookin and cant seem to find what im lookin for?
Is thre anything else that i have to do beable to drop the motor in .. all the neseccary i know, mounts, linkage and so forth.. Just wondering about the fuel injection is the main thing..
Thank u very much for all replys.
Will keep everyone posted on how it is going ..
RIP- 4dr GSR , Skunk2 full valve train and 75 shot..
Currently driving- 95 CX Hatch- JDM 15b Greedy turbo kit
Old Jan 21, 2004 | 10:51 AM
Targa250R's Avatar
be professional
Default Re: Currently Modifing a 1985 carbuerated CRX... (95turbohatch)
For starters, you have to upgrade the entire fuel system, and do all the wiring necessary for PGM-FI fuel injection.
Try http://www.redpepperracing.com for G3 Civic & G1 CRX help.
Old Jan 21, 2004 | 10:57 AM
4crx4me's Avatar
Get the new issue of Super Street. The one with "Top Speed" on the cover.
It's not a how-to but there is an article on a 1984 Mugen/Comptech CRX.
It shows how they got 163 horsepower out of that little carbed 1.5 E W powerplant.
Just a suggestion.
Old Jan 21, 2004 | 03:03 PM
Thanx for the advice about super street, great article.. bu i need some pics and info on the wiring and running fuel lines
thanx
bump
Old Jan 21, 2004 | 03:31 PM
MonteSS's Avatar
good luck!
Old Jan 21, 2004 | 03:50 PM
Thanx i need it becuase i cant find **** out there
anyone out there who has wiring digrams or fuel line digrams???
Old Jan 21, 2004 | 03:57 PM
Blaze45's Avatar
Brrraaaap!
Default Re: (95turbohatch)
is the best first gen CRX tunning page, hands down, go there and search.
Blaze
Old Jan 21, 2004 | 04:37 PM
4crx4me's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95turbohatch &raquo;</TD></TR><TR><TD CLASS="quote">Thanx i need it becuase i cant find **** out there
I would say that it's far cheaper and easier to make the carbed engine car go fast, rather than try to make it EFI. Supercharged, turbocharged, Webers, cams, etc They would all be ALOT less time, money, and work, than to add everything you'd need to do a non-EFI - EFI swap. Wiring, electronic advance ( new dizzy?), the WHOLE fuel system, fuel tank, fuel lines and pump and filter to IM.
But if you feel the need, It should be a nice project.
Old Jan 21, 2004 | 05:34 PM
Think its cheaper to make the carb go faster??
Well.. what is exctally need to do the d15b turbo swap into the crx?
sorry to be a pest just getting into the first gen crx scene...
and i want to come out with a nice set up in the first gen crx ,and i think to be fuel injected with it will turn lot of heads .. and people will really appriciate the first gen
thanx
Old Jan 21, 2004 | 05:50 PM
4crx4me's Avatar
EFI in gen1 carb CRX would turn heads, but are you up to the job of installing it?
To make more power from a carbed car, the first step would be a new IM and Weber carbs, maybe a cam. From there you need to start reading evertything you can about getting HP out of carbed CRX's.
Old Jan 21, 2004 | 06:23 PM
Phaze2 Mike's Avatar
Default Re: (4crx4me)
Let me help 95turbo out a little.
Things he needs to know:
1: Is the d16z6 a bolt-in mount wise?
2: Will the axels fit into the 85 hubs, or rather, what susp/brake upgrade (GSR etc) will be good and will fit the d16z6 axels?
3: How do you we run his car obd1 so we can use hondata on it?
4: Stop giving him carb ideas!
Old Jan 21, 2004 | 06:59 PM
4crx4me's Avatar
Default Re: (yellowfever)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yellowfever &raquo;</TD></TR><TR><TD CLASS="quote">Let me help 95turbo out a little.
Stop giving him carb ideas!</TD></TR></TABLE>
To be honest I really don't know HOW-TO install an MPFI set-up into a carb CRX, I would find it too daunting of a job. I just thought it would be easier to hop-up the car as it stands.
Now, the question is, do YOU realise how hard it would be?
From the little bit I've read. You will NEED the ENTIRE fuel system from filler neck to injectors and everthing in between from an 85-87 CRX Si, Then BOTH engine and cabin harnesses. And then you would need to run ALL the MPFI wiring, Body mounted sensors, MAP, Purge solenoid, vacuum lines, ECU mounting, etc. What a PITA.
Run hondata??? OBD1??? Right now the car is OBD non-existent LOL
He has NO MPFI wires in the car he would need to install ALL that FIRST.
Old Jan 21, 2004 | 08:18 PM
WOW
Seems insane, think i am hoping of the 1st get crx ban wagon..
Sellin it prob.. if anyone is interste let me know
Old Jan 21, 2004 | 08:41 PM
4crx4me's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95turbohatch &raquo;</TD></TR><TR><TD CLASS="quote">WOW
Sellin it prob.. if anyone is interste let me know</TD></TR></TABLE>
If your goal is the swapping in of a more powerful engine, easily. Selling it is probably the best option at this point, unfortunately.
Old Jan 21, 2004 | 08:45 PM
Yes it def is, to much to do that FI garbage in the crx..
But thas alot for all the feed back,
appricate it alot
95cxturbohatch
soon to be runnning 12's
Old Jan 21, 2004 | 09:47 PM
4crx4me's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95turbohatch &raquo;</TD></TR><TR><TD CLASS="quote">Yes it def is, to much to do that FI garbage in the crx..
appricate it alot
Just find an 85-87 CRX Si or any 88-91 CRX, they're already wired for EFI, it makes things alot easier to swap, then.
Old Jan 22, 2004 | 09:32 AM
Yea it def does..
ill lookinto it thanx alot for the info man
Old Jan 24, 2004 | 11:57 PM
Hoosier Daddy's Avatar
Just get a carbureted ZC motor
Old Jan 25, 2004 | 06:59 AM
Dont want to bother with it.. just want to sell it at the moment..
bump
Old Jan 25, 2004 | 11:48 AM
firstgenrex's Avatar
instead of using an si parts car to do the fi swap, id say buy a wrecked 92-95 civic or sumthign and just put the whole harness from taht into ur crx, im guessing its gonna be a more race car so maybe if the dash lgihts dont wokr etc. it wouldnt matter. i just thought of a crazy idea too, keep the crx harness, and put in the civic harness too, just plug it to the engine and leave the rest unplugged, thats a really dumb idea i think, but u could like do somehtign like that, i was trying to think abut it but its too much for me to put together ill post more if i research how everything would work
Old Jan 25, 2004 | 03:51 PM
Default Re: (firstgenrex)
Yea im not even going to mess around wiht it anymore..
Just going to put the money i was going to put in the crx into my turbo hatch..
but thank you for the info everyone..
onurcrx
Oct 4, 2009 11:44 AM
tenedor sports
Aug 1, 2007 07:29 PM
Mechman456
Sep 26, 2006 04:15 AM
SiRex91
19
Oct 19, 2005 08:20 PM
715civic
Aug 19, 2005 11:05 AM
