ok to reuse headbolts????
Old Jan 21, 2004 | 08:48 AM
c1civic's Avatar
Default ok to reuse headbolts????
just wondering my motor is almost ready to be built..its an h22 that will hopefully be pushin aourn 210-215whp. is it ok to use the orignal headbolts or do i need to buy new ones
Old Jan 21, 2004 | 08:51 AM
1BadCvC's Avatar
Default Re: ok to reuse headbolts???? (c1civic)
it is ok to reuse the ones you have but id go ahead and get some ARP head studs, for assurance.
Old Jan 21, 2004 | 12:41 PM
kwik92hb's Avatar
no they are one time use only.
Old Jan 21, 2004 | 01:44 PM
c1civic's Avatar
so can i reuse them or not, would like sespomse from people who have actually built an engine...not saying u guys ahvent though
Old Jan 21, 2004 | 02:27 PM
rapid_roy's Avatar
Default Re: (c1civic)
Well, the real question is whether or not they are TTY head bolts. Those cannot be reused.
I also cannot find anything on whether or not Honda uses TTY head bolts. I checked my GSR manual and it mentions nothing about resusing the head bolts.
However......for what it costs to replace them the real question is why would you bother taking the risk?
Cheers,
Sean
Old Jan 21, 2004 | 03:14 PM
FULLTHROTTLE's Avatar
Default Re: (rapid_roy)
For what you are doing you will be ok using them again. As long as they have not been removed and reused more that twice. Honda has a stretch spec but I cant seem to find it.
Old Jan 21, 2004 | 03:22 PM
B18EG6's Avatar
Default Re: (FULLTHROTTLE)
What if you just went 2 or 4 more lb/ft on the torque wrench?
Old Jan 21, 2004 | 03:33 PM
mattssi's Avatar
Default Re: (B18EG6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18EG6 &raquo;</TD></TR><TR><TD CLASS="quote">What if you just went 2 or 4 more lb/ft on the torque wrench?</TD></TR></TABLE>
That won't make up for it! The way i see it is that if they didn't put in the manual that they needed to be replaced every time, then they would get re-used over and over and over! Whice can cause problems! I have used the same head bolts a couple of time now, and no problems, but if I do another tear down, I am going to get new ones! And they are 30.00 from honda, and along with a headgasket (whice are getting more expensive) your looking at almost a 100.00 just for taking off your head. And that isn't in conjuntion to the problem that would have caused you to have removed your head...
Old Jan 21, 2004 | 05:05 PM
ITR_1211's Avatar
Default Re: (mattssi)
While everything is out, you should change the headbolts
Old Jan 22, 2004 | 12:45 AM
L8apex's Avatar
Torque to yield bolts (just like torque to spec bolts) can be reused as long as they're still within spec. Honda has stretch specs for their headbolts and I've never had to replace any H22 headbolts (they were all within spec). Mind you these were warranty engines putting out stock power.
But if you're planning a build up, might as well replace them since they're out.
Mishako129
Sep 11, 2013 08:11 PM
96Formula6spd
Nov 16, 2010 09:10 PM
diagnostic
Jan 27, 2007 04:44 PM
sporkcrx
Jun 30, 2003 07:13 PM
CptMidway
Jun 18, 2003 01:36 PM
