my ecu is throwing a code,I need your help to identify on a non OBD ecu.
Old Jan 20, 2004 | 10:21 PM
JBk24crx's Avatar
Default my ecu is throwing a code,I need your help to identify on a non OBD ecu.
my ecu is throwing a code here is what is the cel code that is throwing.1 long flash then 4 quick short flashes then it pauses and it repeats itself all over again.the ecu is a PR4 with skunk2 chip.its a 91 crx with b18a1 engine swap, please help me out thanks.
Old Jan 21, 2004 | 02:44 AM
ee9_b16a1's Avatar
Default Re: my ecu is throwing a code,I need your help to identify on a non OBD ecu. (JBLSVTEC)
its code 14
search to see what that means...
Old Jan 21, 2004 | 03:02 AM
Davep's Avatar
Code 14 is for the Idle Air Control valve.
Old Jan 21, 2004 | 07:40 AM
JBk24crx's Avatar
Default Re: my ecu is throwing a code,I need your help to identify on a non OBD ecu. (Davep)
thanks I will check it out.
cslegacy
Mar 9, 2007 08:14 PM
ef_you_again
Mar 17, 2005 11:14 PM
Camshaft
Aug 4, 2004 03:09 PM
