DIY door panels
Old Jan 20, 2004 | 09:24 PM
dAng! Kris's Avatar
Default -FIXED- DIY door panels *WRITE UP AT BOTTOM*
I got a 95 teg just showing a DIY door panel re-furbishing so it doesn't match the colors of the seats.
http://www.imagestation.com/my...n0207
Modified by Frozty at 6:43 AM 1/21/2004
Modified by Frozty at 6:52 AM 1/21/2004
Modified by Frozty at 5:45 AM 1/22/2004
Old Jan 20, 2004 | 09:26 PM
dAng! Kris's Avatar
Default Re: DIY door panels (Frozty)
ahhhhhhh noob question how do u post pics
Old Jan 20, 2004 | 09:27 PM
philibuster's Avatar
you needa upload ur pics to the net and from there, u can link them by using the insert image option when writing a new topic, reply, etc.
Old Jan 20, 2004 | 09:29 PM
dAng! Kris's Avatar
Default Re: DIY door panels (silverblurr)
where can i upload pics at?
Old Jan 20, 2004 | 09:32 PM
quikrpm'z's Avatar
imagestation.com
Old Jan 20, 2004 | 09:45 PM
dAng! Kris's Avatar
Default Re: DIY door panels (quikrpm'z)
bump its fixed, thanks for the image station help
Old Jan 20, 2004 | 10:33 PM
es four's Avatar
From: You can be my wingman anytime...., Las Vegas, US
Old Jan 21, 2004 | 04:57 AM
dAng! Kris's Avatar
Default Re: DIY door panels (integra707)
thanks man, do i just put it between the IMG brackets to make the pic show up like that?
Old Jan 21, 2004 | 08:28 AM
ki3t's Avatar
This user can set his title.
Yes but make sure you take out the orig.jpg at then end.
Old Jan 21, 2004 | 09:53 AM
es four's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Frozty &raquo;</TD></TR><TR><TD CLASS="quote">thanks man, do i just put it between the IMG brackets to make the pic show up like that?</TD></TR></TABLE>
yes sir. Put the URL between the img /img brackets.
Old Jan 21, 2004 | 10:02 AM
Smokinsax's Avatar
The Boot
So are you going to do a write up on this or what? looks good so far.
Old Jan 21, 2004 | 11:13 AM
dAng! Kris's Avatar
Default Re: (Smokinsax)
yea I'll get some more pictures and do a write up later tonite for all interested
Old Jan 21, 2004 | 11:15 AM
ef93si's Avatar
i'm down for a write up
Old Jan 21, 2004 | 12:45 PM
JamesQ's Avatar
Default Re: (ef93si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ef93si &raquo;</TD></TR><TR><TD CLASS="quote">i'm down for a write up</TD></TR></TABLE>
same here, it looks great
Old Jan 21, 2004 | 08:12 PM
dAng! Kris's Avatar
Default Re: (JamesQ)
*Write Up*
here's a semi quick write up, before I go to bed.
1. Take off the door panels and disconnect all power window/door-lock/ speaker cables.
2. get fabric from store any color you want. Don't want it too think because you have to push it down the seam between the plactic part of the door and the existing fabric.
3. lay fabric out over existing fabric that you wish to change. Then cut out around that but leave about an inch or a little more around it so you can tuck it and so that it covers the area nicely.
4. I found that spray fabric adheasive works good you need to test this first with a little piece of fabic to that the adheasive doesnt run through the fabric( if the fabric is too thin it will cause this).
I used Stick It spray adheasive on mine and it came out great.
5. Once the fabric is cut out, lay over the area again to make sure its going to cover the whole area. Then take the spray and start at one end. I went from the top to bottom on mine.
6. spray the adheasive onto the existing fabric around the ouside 1st then work the inside. Don't spray the whole thing at once go in little segmentsmaking sure the fabric is laid out nice and flat with no bubbles. Continue doing this with the whole side and then repeat for the other side.
7. Once that is done and dried( i waited 20 minutes) start pushing the fabric down the crash around the area with a butter knife( or anything reasonably thin with mass) . making sure you don't develop wrinkles or pulls.
8. Trim off the extra so that all you see is what the picture posted above looks like and your done.
Don't be afraid of getting the adheasive on the plastic door panel it's self, some rubbing alcohol fixes it right up.
I realized today that I can take out the old fabric all together and lay the cushion with the new fabric all together. It looks just as good.
If anyone has any more questions feel free and ask, I can try to get some pictures tomorrow.
Or if anyone is intersted in my doing there door panels hit me up with a PM or AOL I/M s/n froztyluderacer or via email kriskovanda@***.net
Old Jan 21, 2004 | 08:50 PM
ef93si's Avatar
so u didn't paint the actual door pannel fabric...you put a whole new layer on?
...also, does the fabric paint make the fabric feel different? like harder or more grainy?
Old Jan 21, 2004 | 08:57 PM
dAng! Kris's Avatar
no i didn't paint mine, i put fabric over the existing fabric. fabric paint, I don't really like that stuff kinda made it feel harder and cracked after a while
Old Jan 22, 2004 | 03:46 AM
dAng! Kris's Avatar
Default Re: -FIXED- DIY door panels *WRITE UP AT BOTTOM* (Frozty)
ttt
Old Jan 22, 2004 | 05:21 AM
ef93si's Avatar
yea, that's what i thought, that's why i didn't wanna do that
Old Jan 30, 2004 | 09:39 PM
dAng! Kris's Avatar
would anyone be interested in me doing there panels?
Old Jan 30, 2004 | 09:43 PM
B18bEK's Avatar
do you have any experience with painting the vinyl on the door panles (like tan to black)
Old Jan 30, 2004 | 11:20 PM
rodrez.'s Avatar
Looks damn good
Old Jan 30, 2004 | 11:36 PM
@ries's Avatar
Default Re: -FIXED- DIY door panels *WRITE UP AT BOTTOM* (rodrez)
Good job buddee
Old Feb 2, 2004 | 08:24 AM
dAng! Kris's Avatar
Default Re: (B18bEK)
i don't have any experience painting the vynil, I wish i did, my ls has tan interior and i hate it, I was thinking of taking my grey interior out of the gsr and swapping it since my gsr is more of a autocross/racing event car now
Old Jun 7, 2006 | 08:21 PM
HomeDepotMade's Avatar
Default Re: (Frozty)
well im going to paint my whole interior black b.c i have tan. and i also wanted to change the fabric on my door pannels. i did a test on one of the trunk liners.
http://www.team-integra.net/fo...ion=1
ekcoupeh22
Sep 19, 2011 10:13 AM
white_ej6
Oct 31, 2009 11:06 AM
specoperformance
Sep 15, 2008 03:26 PM
DOHCgarage919
Dec 27, 2006 10:16 AM
