integra healdights different?? 94-97 and 98-01
Old Jan 20, 2004 | 02:16 PM
daddymaxx's Avatar
Default integra healdights different?? 94-97 and 98-01
ok I know how the 94-97 integras are somewhat cosmetically different from 98-0 but are teh headlight assembly actually different?
Old Jan 20, 2004 | 02:18 PM
T3mp3sT's Avatar
Default Re: integra healdights different?? 94-97 and 98-01 (daddymaxx)
i have a set of 98 headlights on my 97 teggy... so the mounts are apparently the same on those two years but the 98's are longer... other than that, i haven't NOTICED many other differences but of course I really wasn't inspecting them so thoroughly
Old Jan 20, 2004 | 07:24 PM
Creep's Avatar
Default Re: integra healdights different?? 94-97 and 98-01 (T3mp3sT)
The headlight assemblies are physically different.
i.e if you wanna use a 98 bumper on a 97 you need the headlights.
Is that what you meant?
Old Jan 20, 2004 | 08:20 PM
daddymaxx's Avatar
got in a little fender bender. it's a 2000 teg, but I can get 94 headlights CHEAP.
Old Jan 20, 2004 | 08:46 PM
CrazyModGSR's Avatar
Default Re: (daddymaxx)
94 headlights will bolt in the same, but the holes where the headlights go in the bumper (if stock) won't fit correctly, because the headlights on the 98-01 are slanted slightly more inward than the 94-97.
Old Jan 20, 2004 | 08:53 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
The ONLY difference between 94-97 and 98-01 lights is the clear plastic cover in front. Everything else is exactly the same. The clear cover from a 98 headlight will fit on a 94 housing and vice versa.
Old Jan 20, 2004 | 11:56 PM
svtec's Avatar
L D E S
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by daddymaxx &raquo;</TD></TR><TR><TD CLASS="quote">got in a little fender bender. it's a 2000 teg, but I can get 94 headlights CHEAP. </TD></TR></TABLE>
i think that would be a bad move.
a temporary fix yes, but permanent no.
jdmitrdc2
Feb 22, 2009 05:17 PM
erikiksaz1
Dec 3, 2008 07:44 AM
93(Civic)EG6
Sep 15, 2007 11:42 AM
allmotor.net
Dec 16, 2002 03:00 PM
XaznPKdogX
Jan 15, 2002 12:57 PM
