Iab sensor? Ls/vtec into a crx
Old Jan 20, 2004 | 12:34 PM
88 turbo crx's Avatar
Default Iab sensor? Ls/vtec into a crx
Hey guys i just did an ls vtec swap into my crx. Im not sure what the Iab sensor is and where its located? I have a ls block and a gsr head.. made much more work for myself, should have went b16 . Anyways i also am getting a high idle, a map sensor code and crank angle code... The crank angle code would be the 2 wires to the distributor correct? i went from dx to zc a while back and ran these wires already and pretty sure i have them right... i have an obd0 b16 distributor.. if anyone can help me out or sees anything wrong with my set up
please let me know
Btw im running a pr4 ecu to test for codes... i do have a p28 and a conversion harness which i will hook up with a uberdata chip after i get rid of the codes
mattdott
24
Jan 30, 2014 02:19 PM
osbunjosh
14
Apr 24, 2011 05:38 PM
handlebarsfsr
Sep 13, 2006 08:54 PM
jccrxtuner916
13
Jan 26, 2006 07:07 PM
88 turbo crx
Jan 20, 2004 03:55 PM
