which pistons in an A4 block?
I will make this short and sweet... im planning to run forged 12:1 cr pistons on my N/A setup, along with that i will <U>probably</U> be using pauter rods, JUN cams, and ferrea valvetrain. my question is, is which brand to go with? i want something that has slightly deeper valve reliefs because i might run slightly larger valves, i also want something that is fairly lightweight and most importantly high quality. thanks guys
what kind of headwork would need to be done so that the 90mm flows correctly? planning to run jun's with ferrea valvetrain but im unsure on the size of valves stock, +.5mm, +1.0mm?
Hatchman23
Oct 17, 2016 07:31 PM
djteggy99
Mar 19, 2010 07:41 AM
mr_magoo
21
Nov 8, 2005 07:57 PM
mr_magoo
Nov 2, 2005 09:06 AM
