Help I need a wiring harness for my b16a !!!!!!!
Old Jan 20, 2004 | 08:12 AM
Hondzas's Avatar
Default Help I need a wiring harness for my b16a !!!!!!!
I have a b16a that i droped into my crx but the wiring is all butchered up, so i want to replace the harness. Honda wants to charge me $600 dollars for a wiring harness is there any other cheaper route then this one? Can i use a harness from a different engine that would be more cost effective? Please help guys im an a spending defficet.
Old Jan 20, 2004 | 08:18 AM
RenoRacing's Avatar
Default Re: Help I need a wiring harness for my b16a !!!!!!! (Hondzas)
you should be able to add a few wires to your existing harness in the crx. If the crx is an hf or si then it's a plug and go startup, just add knock sensor, vtec oil pressure, vtec itself, and a second o2 sensor. Kinda depends on what ecu and what chassis model you have. It's definately easier to just add the few wires to it even if the multipoint conversion is part of the wiring. less than 14 wires all together.
Old Jan 20, 2004 | 10:55 AM
goforbroke's Avatar
MEAT PATTY
Default Re: Help I need a wiring harness for my b16a !!!!!!! (RenoRacing)
I have a 88 crx si engine bay wiring harness and resistor box if you need it, just let me know.
wallabee32
Jan 17, 2007 10:38 PM
fwdftw
Mar 6, 2005 10:09 PM
markdman
Sep 22, 2003 09:34 AM
PimpTightSi
Jan 21, 2003 11:25 AM
