need to know what year the clutch cable and throttle cable for a b16swap on a crx88
ok im getting my car swap this weekend and the guy doing the swap said, it will be a good idea to also change the throttle cable and the clutch cable. he also said get it from an 91 teg. but im not sure. is that right. 91 teg????
and where do i get that???
i was told, to use the one for integra.i think it was from a 91 but im not sure. but he said it would be better.cause they are thicker and stronger compare to the ones that i currently have on a 88 hf.
you prboably can get away with using several different cable combo's but, I used 90-93 integ throttle cable and my stock 90 si civic clutch cable.
use 90-93 teg throttle cable and clutch cable
stock clutch cable may work but won't give enough adjustment.. on my car it wouldn't let clutch fully disengage
Throttle cable = $15.74
Clutch cable = $42.12
These prices are from http://www.acuraparts247.com/s...e.jsp
Also I only bought the throttle cable, and used my 91 HF clutch cable.
CRexcellence
Dec 11, 2002 03:12 AM
13secondcivic
Feb 17, 2002 06:38 PM
BoostinDC2
Feb 17, 2002 05:41 PM
