Those running Yoko AV ES100's
For those of you running the ES 100's...
do you get a slight pull to the right while driving on a flat road? This is the second set i've had and both have done the same thing. I would assume this is due to the multi directional tires? An alignment has been done and it still does the same crap.
Mine don't and never have. Checked the pressure in your tires? Define a flat road. All roads if built right will have a slope to them for drainage. It might look flat . . .
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Asahi »</TD></TR><TR><TD CLASS="quote">Mine don't and never have. Checked the pressure in your tires?</TD></TR></TABLE>
That'd be what I'd mess with before going to another reputible shop for an alignment.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Asahi »</TD></TR><TR><TD CLASS="quote"> Define a flat road. All roads if built right will have a slope to them for drainage. It might look flat . . . </TD></TR></TABLE>
4 degrees minimum from the center to the curb from what I've read. And yes even if it looks flat as hell I'm not sure if I could dectect a 4 degree difference visually. But, for certain every Integra I've owned (LS's & R's) have pulled to one side or another on rutted or cambered/sloped roads.
That'd be what I'd mess with before going to another reputible shop for an alignment.<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Asahi »</TD></TR><TR><TD CLASS="quote"> Define a flat road. All roads if built right will have a slope to them for drainage. It might look flat . . . </TD></TR></TABLE>
Hmm
I guess what I meant by flat roads was newly paved...not all fudged up by wear and tear...it was relatively smooth with no bumps and other wear features.
I havn't checked tire pressure. I assume keeping all of them at the same psi within spec should suffice?
Tire stores call that a radial pull. Some tires do it and some don't. Try to rotate them front to back and see if it still does it. Also check the tire pressure.
Hope these are good tires, mine should be in today. Can't beat the price.
I really enjoy mine, although I do notice a pull every now and then. Some of the freeways here in Cali have weird pave patters, so I notice these tires and the Azenis as well tend to follow the direction of the pave rather than the lane. So I do get side to side movement every now and then. It is totally manageable though. I just consider it normal.
Seem to be getting mixed responses on the right pull. However, it does seem pretty normal from what I hear... so I'm not too worried about it. As mr. clockwork said, it's pretty manageable.
The tires are cheap and effective as hell.
This may sound Really Crazy and Stupid but, make sure all 4 tires are exactly the same size.
Why you may wonder?
The last time more than a few of us were at Limerock for a DE, some poor guy in a white RSX actually had different sized Azenis on his car, but not totally his fault. He reported that he bought them from Discount tire direct some few days earlier and just installed them not thinking to check that they were all the same size. Or even thinking that DTD would make such a mistake.
I don't remember off hand what the size difference was but he had 2 of the smaller ones on the passneger side and 2 of the taller ones on the drivers side and swapped to taller rear and smaller front after one of us pointed it out to him.
Seriously.
Why you may wonder?
Seriously.
mine dont pull at all. i just got my tires yesterday. The tire shop scratched my rims and gave me all four tires for 150 bucks mounted and balanced
-Denny who is a show ***** and is some how not very traumatized by this inncident
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by georgejetson »</TD></TR><TR><TD CLASS="quote">Mine follow the lines of the road, my car is all over the place.</TD></TR></TABLE>
mine is a bit like this too, which could be a Toe issue, among other things.
