P28?
Old Jan 20, 2004 | 05:00 AM
Z6REX-SI's Avatar
Default P28?
I need to know what the last couple of digits are on a manual P28 Ecu.
Old Jan 20, 2004 | 06:12 AM
vaskater's Avatar
Default Re: P28? (Z6REX-SI)
I've got a P2T right here next to me, but I'll go out and check the P28 that's in my car in a little bit after I get a cup of coffee in me. You're in Richmond, huh?
Old Jan 20, 2004 | 06:18 AM
b18cx's Avatar
http://www.hondaswap.com/~pills/autotomanual.html
Will tell you everything you need to know.
try the search function. Took me about 2 minutes to get this for you.
Old Jan 20, 2004 | 06:54 AM
vaskater's Avatar
Default Re: P28? (b18cx)
Mine is P28-A52.
Old Jan 20, 2004 | 07:20 AM
Z6REX-SI's Avatar
Yes, I am in Richmond.
Thanks guys.
Old Jan 20, 2004 | 04:49 PM
vtecrx's Avatar
Default Re: P28? (vaskater)
Mine is P28-A52.
Auto
Old Jan 20, 2004 | 08:12 PM
PHiZ's Avatar
Default Re: P28? (vtecrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondata website &raquo;</TD></TR><TR><TD CLASS="quote">If the second to last number is a 5, then you have an automatic ECU (for OBD-1 USDM ECUs). If the 2nd to last # is anything but a five you have an ECU for a 5 speed. If you have a jdm obd-1 ecu, look at the last 3 digits: 900 or 901 will be an automatic.</TD></TR></TABLE>
-PHiZ
Old Jan 20, 2004 | 09:18 PM
vaskater's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vaskater &raquo;</TD></TR><TR><TD CLASS="quote">Mine is P28-A52. </TD></TR></TABLE>
Hmmm... I guess my box has been reprogrammed from an auto, then. Weird.
Old Jan 21, 2004 | 04:42 AM
BlueCrxNC's Avatar
So can anyone verify that doing what the above link says will work (Changing resistor values/jumpering, etc to convert an Auto ECU to Manual?
Modified by BlueCrxNC at 9:43 AM 1/21/2004
Old Jan 21, 2004 | 05:39 AM
vaskater's Avatar
Default Re: (BlueCrxNC)
Well, it would seem that it is possible, since I have an automatic P28 OBD 1 ECU in my manual transmission civic.
Old Jan 22, 2004 | 06:27 AM
b18cx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueCrxNC &raquo;</TD></TR><TR><TD CLASS="quote">So can anyone verify that doing what the above link says will work (Changing resistor values/jumpering, etc to convert an Auto ECU to Manual?
Modified by BlueCrxNC at 9:43 AM 1/21/2004</TD></TR></TABLE>
YES, it does work. Have done several P28's like that. Work great.
krazieV
Oct 17, 2007 10:47 AM
pnk_03
Apr 30, 2007 09:08 PM
Dark91zc
Jun 13, 2005 10:18 PM
Acura_I-RS
May 21, 2005 06:50 AM
SOHCmaster
Mar 30, 2005 06:00 AM
