FS: 95 integra ls/turbo
Im selling my integra it has 126xxx miles. It has a APEX N1 universal muffler, kyb agx adjustible shocks, ground control coilovers, a ACT clutch, and a rev hard stage 2 turbo. The motor has two problems and that is it all. It has a minor oil leak near the cam seal. And the car also has positive crank case pressure from blow by of the piston rings which is cause oil to come out of the valve cover breather. I have a home made oil catch can try to catch the oil as of right now, but it is not being driven anyways.
Exterior damage can be seen in the pictures, but ill give a little bit of a discription of it. the front fender has a ding in it, the passenger door has some minor dings in a row of a car door hitting it over and over again, and the front left fender has a small ding in it too. Back bumper has paint scratched off from some body with a buggy at walmart. paint is getting faded too, but it is not that bad. Tires have about 40% in the front and the back has about 60-70% of life left in the tires. The antenna is broke, but still picks up just as good as if it wasnt broke.
Interior has a paint spot on the diriver seat. And the stitch is coming out some. As you can see in the pictures. It has a diamonds plate shifting plate. And the ceiling is kind of dirty.
Also comes with a Pioneer cd player, four gauges (boost, oil pressure, water temp., and fuel pressure) two of them are installed but dont have a gauge pod. And brand new piston ring set will also come with the car.
This car before the blow by problem had great pick up. It was never ragged out. And is capable of running in the low 13's with good tuning.
I am asking 7000 or best offer. If this helps I bought the car for 5500 and bought the turbo and clutch for 3500. So my loss is your gain.
PICTURES are here: http://www.hondaswap.com/galle...d=841
If you have any questions feel free to email me at turbointegra@elmore.rr.com
Thank you, Kyle.
Modified by civic15.8 at 11:01 PM 1/22/2004
Thank you, Kyle.
