can you take a y8 head off without taking the cam out?
yeah you can its the same thing you would do to a dual head
Edited: oops sorry umm no you dont need to take the cam out to pull off the head
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OnebadJdmEg6 »</TD></TR><TR><TD CLASS="quote">yeah you can its the same thing you would do to a dual head
Edited: oops sorry umm no you dont need to take the cam out to pull off the head</TD></TR></TABLE>
Uuummmmmm, yes you can pull the head on a SOHC without pulling the cam. NO you can not pull the head on a DOHC without pulling the cams. Cams sit right above the head bolts. LS, GSR, B16, ect.........
yea on SOHC the head bolts on are on both sides of the cam, unlike on a DOHC the cams are right above the head bolts which makes you remove the cams to remove the head.
Lewdin' Incognito
Jul 22, 2005 12:35 AM
