Changing 4th Gen Prelude Shift Boot
Old Jan 19, 2004 | 10:16 PM
DSmithBoi's Avatar
Default Changing 4th Gen Prelude Shift Boot
My shift boot is torn to **** and I have a new one to swap in, I checked out the entire assembly and took it apart to the boot and the plastic ring. I can't see a way to take out the boot without tearing it all up to ****, if anyone has done this before please help me out a bit. Thanks in advance
Old Jan 20, 2004 | 07:40 AM
prelittlelude's Avatar
Default Re: Changing 4th Gen Prelude Shift Boot (DSmithBoi)
usually when you buy a shift boot, it comes with the plastic ring that is what the material is molded into. if you got a shift boot without a plastiv ring at ythe bottom you fucked, unless there is another way to do it
in this image you buy the shift boot with the ring attached at the bottom
Old Jan 20, 2004 | 12:29 PM
DSmithBoi's Avatar
Default Re: Changing 4th Gen Prelude Shift Boot (prelittlelude)
Well i guess im fucked bc it didn't have the ring its just one of them cheap ractive universals hmm... anyone else give it a shot....
Old Jan 20, 2004 | 12:35 PM
Sephro's Avatar
you can ghetto patch it and it will come out fine... I am trying to remember how it is attached exactly. IIRC there are staples in there. But you can pull the old one off the ring and find a way to attach the new one... So just have to be a bit creative and ghettofab it. It should look good because you should only be doing all the work on the bottom side that won't show. Hope you know what I mean..
Old Jan 20, 2004 | 12:58 PM
Behan's Avatar
Default Re: Changing 4th Gen Prelude Shift Boot (Sephro)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sephro &raquo;</TD></TR><TR><TD CLASS="quote"> IIRC there are staples in there. But you can pull the old one off the ring and find a way to attach the new one... So just have to be a bit creative and ghettofab it. It should look good because you should only be doing all the work on the bottom side that won't show. Hope you know what I mean..
there are staples, i just removed the staples, placed the boot around the ring. then used a staple gun to re-connect.
ernestoG's Avatar
your reminding me how badly I need a shift boot...swaped in mt after getting the car and I STILL have that giant hole but with the pretty sparco ****..wtf??? so lazy.
Old Jan 20, 2004 | 01:40 PM
kb798's Avatar
1)remove the shift **** by pulling down on the ring and the boot. It takes force, but it should pop down. Then you can unscrew the stock shift ****
2)remove the center console by unscrewing 4 screws on each side, and 2 screws underneath the climate control console.
3)pull up the e-brake as high as possible, and move the shifter into reverse. It takes a little bit of finesse to get the console out, but pull it back, and then up - be patient and it'll come out.
4)the shift boot is attached to a bracket that is screwed into the center console with 2 screws. Unscrew them and you have your shift boot and bracket.
Hope it helps
Immortal-Prelude
Nov 24, 2007 11:39 AM
LEGiTLUDA
Oct 6, 2007 08:02 PM
hk350
Oct 27, 2004 03:45 PM
donger
Jun 14, 2004 10:27 PM
NONKonformyst
Aug 22, 2002 12:19 PM
