weird idle
Old Jan 19, 2004 | 05:26 PM
Convoy's Avatar
Default weird idle
i just finished doing my swap, its a 95 gsr in a EG, no the problem is that when the car started it idlied fine at 1500 then after the car got warm and and i started driving it it started idling from 1000 to 1500. help!!!!
i know check the vacumm, i already did and nothing
Old Jan 19, 2004 | 06:17 PM
hondatim's Avatar
Default Re: weird idle (Convoy)
Will need to set base idle.
Disconnect IAC with engine running and see if idle drops, engien dies, or no change, if engine dies or no change in idle speed when IAC disconnected, idle too high or too low. When you disconnect IAC with engine running, base idle should be 500-550 rpm, with no accessories on. Thsi is with the engine at operating temp.
Do not, I repeat, do not use your tach on the dash for this. (Very Inaccurate) Need to use inductive tach or timing light with tachometer built in. Much more accurate. After setting base idle to 500-550 rpm with IAC disconnected, turn engine off, reconnect IAC and clear codes. Restart engine and check idle speed. Should be set at 700-750 rpm now.
Also, want to make sure coolant level is topped off and no air pockets in system. If air in system or low coolant, will cause IAC to respond very irratic.
Hope this helps
Old Jan 20, 2004 | 05:57 AM
Convoy's Avatar
thanks
Old Feb 2, 2004 | 05:44 AM
Convoy's Avatar
still idles
Old Feb 3, 2004 | 09:23 AM
Convoy's Avatar
help
Old Feb 8, 2004 | 08:22 PM
romJones's Avatar
same problem...would really like to know problem
Fraser1989
Nov 25, 2015 12:29 AM
virgilr
Jun 17, 2007 04:13 AM
ic89
Oct 14, 2006 02:51 PM
carblegal
Dec 25, 2004 09:51 PM
