multi swap help
Old Jan 19, 2004 | 05:01 PM
89a6T's Avatar
Default multi swap help
i finished all the wiring today but nothing.i turn the key and you here a real high pitch whistle,but its not loud. smell gas. i dont think im getting spark but ive looked over the wires several times and everything looks ok. only thing i rigged was the two pins by the ecu but it looks like theyre making contact, throwing codes 6&10. map sensor & .........also the yellow and red from a3&a7 where do they go? i ran the wires the from the ecu to the engine bay but what do i do w/ the wires that were originally coming from the engine to a3&a7? really need help. TIA.
i also have two wires left over from the dx harness where the 3 injector plugs would have been. they are green w/white stripe and orange/redish w/yellow stripe.
Old Jan 20, 2004 | 10:37 AM
89a6T's Avatar
Default Re: multi swap help (89a6T)
ttt
Old Jan 21, 2004 | 11:08 AM
89a6T's Avatar
blew the head gasket on the old d15 so i swapped on a si head&IM. its related to the wiring but this is my first time doing a multi swap so im not sure what it could be. and the sound is more of like when you turn on your tv or something electronic, real high pitch sound. i have A3 & A7 left coming from the car. and a green/white stripe and orange or red/yellow stripe left over, under the hood, that were on the old dual intake manifold. throwing codes 6 &10.
ryanevansoh
Mar 27, 2009 04:06 PM
kalm_traveler
24
Dec 25, 2007 07:52 AM
Josh22999
Feb 19, 2007 09:19 AM
dafro42
Jan 2, 2007 05:53 AM
BeEfiEBuNz
Oct 20, 2002 02:39 PM
