Want to Buy Want to Trade/Want to Buy
WTB: Starter for my 94 GSR
Old Jan 19, 2004 | 04:19 PM
ChillOutWayne's Avatar
Default WTB: Starter for my 94 GSR
well my starter really started acting up and needs replacement. im not looking to spend alot of doh and i dont know if i need a OBD1 series or not, if anyone has one available im in chicago and would need it soon. PM or respond here, thanx.
Old Jan 19, 2004 | 04:20 PM
Default Re: WTB: Starter for my 94 GSR (ChillOutWayne)
also possible trade +- cash too with stuff listed below. thanx
Old Jan 21, 2004 | 09:02 AM
vtecb20coupe's Avatar
B A N N E D
got a starter for ya. check im.
Old Jan 21, 2004 | 09:03 AM
b18bturbo's Avatar
i have starter as well let me know
Old Jan 21, 2004 | 09:51 AM
thank u, i appreciate the reply...i got one pending, ill let u guys know...thanx
Old Jan 28, 2004 | 08:48 AM
thanx for the help guys, i picked one up (thanx tegpilot) but havent put it on yet...so everything seems to be all good now
Old Jan 28, 2004 | 04:36 PM
tegpilot's Avatar
not a problem...let me know if you come across needing anything ...
thanks again
Old Jan 28, 2004 | 06:20 PM
Default Re: WTB: Starter for my 94 GSR (tegpilot)
i just remembered that i should have had u look at my car, (although i didnt have it there)...i just did a rebuild and was wondering about this sound im having, also some other questions. u guys tune VAFC right? how much would it cost me to have it dynoed and mild tune? thanx
Old Jan 29, 2004 | 08:42 AM
tegpilot's Avatar
well mild tune with dyno and A/F for the hour we charge 120.00...
hmmm what kinda sounds you got?
Old Jan 29, 2004 | 10:12 AM
wow im retarded, i responded thinkin u meant sounds like stereo...haha...anyway, im getting a light knock from the motor, but i can mainly only hear it below 3k and alot at idle. its not that loud but it is noticeable. and im not positive but i might be consuming some oil. I got a GSR block bored to 81.5mm with CP 9:1 pistons and eagle H beam rods, ACL thrust washers and rod bearings and Federal Mogul mains...dont quote me on that oil consumtion tho, it might just be different conditions im checking it in. also in the last 2 weeks i have thrown a CEL for knock sensor maybe once, then today i got it 5 times. im trying to figure if its serious or not..thanx
Modified by ChillOutWayne at 12:08 AM 1/30/2004
Old Jan 30, 2004 | 08:07 AM
tegpilot's Avatar
Default Re: (ChillOutWayne)
Well the CP piston has a slight knock to them kinda like a diesel truck engine.But shouldn't be that overwhelling . Also check you knock sensor i've seen alot of ppl break them off when rebuilding motor and try to put them back on glueing them,That never works. cause i might get connection time to time. that why you getting th CEL. IF you driving in this crazy cold weather, make sure you warm it up good before drive, if not drive with low RPMs .
Old Jan 30, 2004 | 09:17 AM
so i can expect a light knock at idle with the pistons? its not overwhelming by any means...also if the knock sensor is screwed up would i get a CEL all the time, not just once in a while? ..also this cold weather does blow hardcore, but i NEVER even move it without letting it warm up at least 15 mins, and even then after driving and all it never gets above 150 degrees. also wat r yur thoughts on if my oil is coming out looking like garbage after just a few hundred miles at most? BTW ther is about 750 miles on the rebuild and ive done a few oil changes.
Old Jan 31, 2004 | 03:48 PM
EFresh's Avatar
i got a b series starter. email me if you want it.
Old Feb 1, 2004 | 02:06 PM
thanx, but i picked one up already,
theslugbug
Jun 16, 2010 08:41 PM
ilovemyeg
Jun 10, 2005 04:35 PM
STUCKED
Mar 23, 2005 11:14 AM
TurBoTeG
Aug 3, 2002 04:23 AM
