I want to have 8.8:1 or so...
Old Jan 19, 2004 | 03:46 PM
birz's Avatar
Default I want to have 8.8:1 or so...
I have just bought some Ross pistons for my B18B1 1999 they are rated at 8.5:1 CR, since I'm not planning to go over 10psi on my T25 in any case, I want to increase the CR to let's say 8.8:1,,, what brand and what thickness of headgasket should I use? (if it's achiveable)
thanks alot.
Old Jan 19, 2004 | 03:48 PM
99blackcivicSi's Avatar
Default Re: I want to have 8.8:1 or so... (birz)
dude that is WAY to low bring it up to about 9.5 9 at the very least man.
Old Jan 19, 2004 | 03:51 PM
streetlvlhatch's Avatar
Default Re: I want to have 8.8:1 or so... (99blackcivicSi)
i got 8.5 comp pistons too on an ls and im gonna add a gsr head. What will my comp be? What should it be?
Old Jan 19, 2004 | 03:53 PM
birz's Avatar
I want to tank on 91 octane, with my current setup I only could tank on 94 octane,, is I tanked on 91 it would detonate. I'm boring out my sleeves to 81.5mm,,, will I really feel a difference between NOW stock CR 9.2:1 (81mm),,, and when I'll put new pistons in at 8.8:1 (81.5mm) ????
if yes what amount of HP/torque we're talking? like 5? 10? 100?
Old Jan 19, 2004 | 04:35 PM
Blaze45's Avatar
Brrraaaap!
Dude your going to run a t25 on a built b series?
Blaze
Old Jan 19, 2004 | 05:07 PM
mildly.interesting's Avatar
hey my ls is 8.5:1 with Arias pistons and Crower h beams, why is that bad? I run 93 octane with 15 lbs and get 300+, and with C16 and 26 lbs, im knocking hard on 500hp...however, it does seem to idle kinda funny, but that may big my big-*** Web cams too...
Old Jan 19, 2004 | 05:25 PM
birz's Avatar
Default Re: I want to have 8.8:1 or so... (Blaze45)
why would'nt I run a T25 on a SEMI built B18,,, I'm only changing the pistons that's it,,
Am I doing something wrong?
Old Jan 19, 2004 | 05:30 PM
TurboJesse
Guest
Posts: n/a
you stock motor can handle more power than that turbo can make..
Old Jan 19, 2004 | 05:35 PM
birz's Avatar
Default Re: I want to have 8.8:1 or so... (Mpir3)
yeah but the thing is I have done a leakdown test cuz it was smoking badly (blue) hence my cylinder #3 did show poor nuumers cant recall though,,, that's why I bought some new pistons,,, maybe when I'll get rich I'll buy a bigger turbo and better fuel management. But for now the pistons were the only thing I could afford.
Old Jan 19, 2004 | 05:37 PM
birz's Avatar
let's get back to my initial question please wich head gasket? and how thin?
I'm running the SMC+ hack plus an msd BTM (450cc DSM) btw
Old Jan 19, 2004 | 06:54 PM
birz's Avatar
no suggestions at all?
Old Jan 19, 2004 | 08:17 PM
Blaze45's Avatar
Brrraaaap!
A t25 is just really small for that motor and up top it will fall on its face and lose efficiency (not sure I spelled that right), see if you can pick up something a little bigger.... Your fuel setup sounds ok, you should look into upgrading the pump with those injectors...
Blaze
Old Jan 19, 2004 | 09:06 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by birz &raquo;</TD></TR><TR><TD CLASS="quote">no suggestions at all? </TD></TR></TABLE>
stock with copper spray man.
Old Jan 20, 2004 | 01:51 AM
liam821's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blaze45 &raquo;</TD></TR><TR><TD CLASS="quote">Dude your going to run a t25 on a built b series?
Blaze</TD></TR></TABLE>
thats what i was thinking. Wheres the SC61? With 8.8:1 you can run like 20psi on pump gas! weeeeeeeeeee
liam
Old Jan 20, 2004 | 02:07 AM
rocket256's Avatar
Default Re: I want to have 8.8:1 or so... (liam821)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by liam821 &raquo;</TD></TR><TR><TD CLASS="quote">
liam</TD></TR></TABLE>
I dont agree there. I say SC34.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blaze45 &raquo;</TD></TR><TR><TD CLASS="quote">A t25 is just really small for that motor and up top it will fall on its face and lose efficiency (not sure I spelled that right), see if you can pick up something a little bigger.... Your fuel setup sounds ok, you should look into upgrading the pump with those injectors..
True; but he has a LS. 6800 is good on that turbo (T25) should be good right. correct me if Im wrong
Old Jan 20, 2004 | 07:52 AM
birz's Avatar
Default Re: I want to have 8.8:1 or so... (rocket256)
Guys I know SC34, GT25, T3/T4, SC61 they would allllllll be good,, but I repeat I cant afford it . And personnaly I drove my car all the summer and it pushed pretty hard, I use to have a CX 106HP before that car so it's a pretty big step . A friend of mine has a GTI 1.8T 2002 (180HP) and I beat him everytime effortless. I have whellspin in 1st 2nd and sometime in third. So, as far as it goes it pushes just perfect for me, I'm not that boost addicted. I just want a clean setup reliable.
Old Jan 20, 2004 | 07:58 AM
birz's Avatar
Oh and btw the spring is at 8psi
Old Jan 21, 2004 | 11:26 AM
birz's Avatar
what thickness???? please please please!!
Old Jan 21, 2004 | 01:15 PM
birz's Avatar
bump-o-matic
424racer
13
Nov 3, 2009 09:24 PM
teggything
25
Jan 25, 2009 06:27 PM
ALLMOTOR CRX
17
May 6, 2007 11:57 AM
azteggi
Apr 10, 2005 06:56 PM
Gant
Mar 14, 2004 12:33 PM
