JDM P13
Old Jan 19, 2004 | 03:23 PM
9deuce9rr's Avatar
Default JDM P13
Hey, i know there's gotta be a thousand threads out there covering this but i'm not finding em. I got a JDM P13 with my H22a and i'm in the process of putting my old Si OBD 1 harness on it. since its outta a 97+ i'm assuming its an OBD 2.... will i need to get a new OBD 1 ECU to go with my harness, or will it work fine?
Old Jan 19, 2004 | 04:08 PM
hksturbolude's Avatar
Default Re: JDM P13 (WhiteLude)
i thought the p13s were obd1 ecus the 97+ ludes use a different ecu
Old Jan 19, 2004 | 04:42 PM
9deuce9rr's Avatar
Default Re: JDM P13 (hksturbolude)
then wut do the 97+ use? that and it says "P13" on every piece of my engine. maybe its a pre 97 v-tec? engine code = H22A
Old Jan 19, 2004 | 08:20 PM
99spanishGT
Guest
Posts: n/a
yeah thats a 4th generatin motor i think 97+ is h22a4 or something like that!!
Old Jan 19, 2004 | 08:27 PM
H22A EG6's Avatar
Default Re: JDM P13 (spanishlude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spanishlude &raquo;</TD></TR><TR><TD CLASS="quote">yeah thats a 4th generatin motor i think 97+ is h22a4 or something like that!!</TD></TR></TABLE>
yea
Old Jan 20, 2004 | 09:36 AM
Built2.0Lude's Avatar
if all it says is H22a and not H22a4 then its a jdm engine which would most likely be obd1.. You should be able to find the year of the engine somewhere on the block (on the side of the engine by the timing belt, on the front of the engine above the exhaust manifold or even on the head)
Old Jan 20, 2004 | 07:30 PM
SiR EJ8's Avatar
the date for mine is on the front of the motor, i believe on the head. it looks like a clock, sort of. 97+ is obd2, but, if you are using a jumper to obd1, then you would use an obd1 ecu. i hope im following this correctly.
sleepyaccord96
Jun 7, 2013 05:24 PM
Brownjd
Feb 2, 2011 03:57 PM
brknlude
Apr 24, 2003 03:21 PM
