Header question: Is stainless steel really worth the money?
Old Jan 19, 2004 | 02:15 PM
explosive's Avatar
Default Header question: Is stainless steel really worth the money?
I'm looking into getting an AN-R header for my H22 del Sol in a little while and I was wondering if it is worth the money to get the stainless steel header instead of the normal one.
I know that it doesn't really matter from a performance aspect, I was just wondering if the header will hold up without being coated in stainless steel. I don't want to have my header rust out in a year, especially when I wont be using header wrap on this.
Normally, I would get the stainless steel, but it's $250 extra and with that money I could buy something else that would help me performance-wise. So I thought that someone here might be able to point me in the right direction because a search didn't really help much.
Old Jan 19, 2004 | 03:41 PM
MrTodd's Avatar
Default Re: Header question: Is stainless steel really worth the money? (explosive)
If you don't want to spend the $250 for the xtra coating (and I don't blame you), I'm sure you could get away with spraying on a good amount of ceramic based high-temp paint on the header. That should help in rust-resistance a bit.
Old Jan 19, 2004 | 08:58 PM
boostn420's Avatar
Usually headers that arent stainless steel are coated, header companyies dont want their product rusting either. the stainless steel looks bad *** if you clean in very good with alcohol and touch it as little as possible, wear clean gloves when you install it. Other than that it looks sweet I dont really see any reason to buy it.
Old Jan 19, 2004 | 09:02 PM
Kendall's Avatar
If you plan on wrapping the header with insulation then I'd go with the stainless as the ceramic coated ones are more at a risk of cracking when insulated.
drew338
Apr 11, 2007 04:38 PM
ANDREW D
Oct 15, 2004 07:03 PM
Bigjussin
Sep 16, 2004 03:37 AM
RCautoworks
Mar 3, 2003 05:03 PM
RacerXintegra2k
Dec 1, 2002 05:42 PM
