how do u put stock oil cooler on ls motor
how do u put the stock oil cooler on a ls block?
the oil cooler has 2 hoses
1 goes to the water pipe and the other goes to the engine block
but the ls motor doesent have anywhere for the other hoses to go
so to run the stock oil cooler on a ls motor do u have to drill and tap a hole in the block your self and if so do u think its really worth it
You can route that line so that it tees into the intake manifold line and into the head.
And, you'll have to use a B16 or ITR main water pipe. You can use the P72 water pipe if you want, but that'd complicate things b/c of the heater hose moving from the thermostat housing to the main water pipe.
