b18b into 93 integra?
Old Jan 19, 2004 | 10:29 AM
weraider30's Avatar
Default b18b into 93 integra?
I found an awesome deal on a 90 integra. I wanted to find out if the b18b that i currently own will bolt directly in to the 90 integra chassis...
I need to know soon, please reply.. thanks.
Old Jan 19, 2004 | 10:42 AM
El_Jefe's Avatar
Default Re: b18b into 93 integra? (weraider30)
yes it'll bolt right in using stock mounts and tranny
Old Jan 19, 2004 | 10:44 AM
weraider30's Avatar
Default Re: b18b into 93 integra? (El_Jefe)
how about wiring? same? or will i have to rewire it? also, do i need the ecu for the b18b or will the b18a ecu work?
I need a b18b ecu plus tranny..
BTW I'm using someone elses name to post this, so if you have anything or want to contact me, im 90civichb on honda-tech, or you can email me at sean@s-icon.com
Old Jan 19, 2004 | 01:03 PM
Devlins 91LS's Avatar
If you use the b18a's ecu & wiring harness, you'll need to use the b18a distributor, injectors, and alternator.
IMO: If you're gonna be usin that boosted b18b, swap it over to obd-1 and use all the b18b stuff because hondata doesn't make an obd-0 unit.
Old Jan 19, 2004 | 10:21 PM
90civichb's Avatar
Default Re: b18b into 93 integra? (Devlins 91LS)
Those posts above from weraider30 were me.. I actually won't be using the "boosted b18" .. just the b18.. he is swaping the turbo on to his future b20/vtec.. the b18b will need a tranny and wiring harness.. plus an ecu.. and whatever else is needed to drop it in
Old Jan 19, 2004 | 10:25 PM
JGDA9's Avatar
Default Re: b18b into 93 integra? (90civichb)
B18B = hydro tranny
90-93 integras = cable tranny
Old Jan 19, 2004 | 10:39 PM
Toadfart's Avatar
Default Re: b18b into 93 integra? (JGDA9)
So just use the tranny from a B18A.
'92 HatchGuy
Feb 20, 2007 03:18 PM
hgw84
Mar 7, 2006 03:03 PM
TurboEM1
Nov 9, 2005 08:57 AM
jaybquick
Jan 25, 2003 02:10 PM
CRXSleeper
17
Sep 17, 2002 06:42 PM
