Exhaust sytem on LS/VTEC
Old Jan 19, 2004 | 09:56 AM
freezerburnv2's Avatar
Default Exhaust sytem on LS/VTEC
I want a 2.5 inch exhaust system on my 2000 Civic 4DR with LS/VTEC. I was wondering if I could get a pre made exhaust for a Civic SI like from magnaflow. Will it just hook right up? or am I looking for custom work here?
Old Jan 19, 2004 | 05:21 PM
elf's Avatar
elf
Default Re: Exhaust sytem on LS/VTEC (freezerburnv2)
Just buy/make an exhuast system for the body, it should have nothing to do with your engine, unlesse you are using a different header.
And for the record, you should be using a jdm type-r header(or dc sports knock off), its the best for an lsvtec setup
Old Jan 19, 2004 | 07:06 PM
Default Re: Exhaust sytem on LS/VTEC (elf)
Yea, I already have a DC Sport Header. I just didn't know if it was shorter or longer where the D series header stops compared to the B series.
Old Jan 19, 2004 | 10:11 PM
bump
Old Jan 20, 2004 | 02:35 PM
b18blove's Avatar
you can buy any style cat back system and either have a cat or test pipe made to fit in the space from the header to your exhaust
Old Jan 21, 2004 | 01:44 AM
KTeller8's Avatar
Default Re: Exhaust sytem on LS/VTEC (b18blove)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18blove &raquo;</TD></TR><TR><TD CLASS="quote">you can buy any style cat back system and either have a cat or test pipe made to fit in the space from the header to your exhaust </TD></TR></TABLE>
that is true, we get a lot of ppl ording our custom exhaust for their swaps for that exact reason.. you can adjust exact length..
Old Jan 21, 2004 | 05:38 AM
vtecb20coupe's Avatar
B A N N E D
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by elf &raquo;</TD></TR><TR><TD CLASS="quote">And for the record, you should be using a jdm type-r header(or dc sports knock off), its the best for an lsvtec setup</TD></TR></TABLE>
not true. for a basic setup and budget racer, then the dc header will work fine. if you really want to get some hp, check into possibly an an-r, headertech header, etc.
Old Jan 21, 2004 | 08:30 PM
vtec69's Avatar
I had the same problem when I was building my ls/vtec
Just go to a good muffler shop and have them make the pipeing and get like a es oval muffler thats 2.5in and out
-Brian
Old Jan 22, 2004 | 04:58 AM
ki3t's Avatar
This user can set his title.
Default Re: Exhaust sytem on LS/VTEC (vtec69)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec69 &raquo;</TD></TR><TR><TD CLASS="quote">I had the same problem when I was building my ls/vtec
-Brian</TD></TR></TABLE>
Listen to him. Go to a muffler shop and get custom piping done w/ an ES Oval.
j_mee_5
Dec 3, 2011 09:49 PM
deafman002
Dec 10, 2008 06:38 AM
aaronISthrowed
Jan 30, 2006 06:21 PM
japan4racing
May 18, 2005 02:05 PM
SPOONup
Dec 25, 2004 10:42 AM
