my dissapointing dyno numbers. b16a turbo
Old Jan 19, 2004 | 08:17 AM
NotPhilTran's Avatar
Default my dissapointing dyno numbers. b16a turbo
heres the setup,
b16a obd0 pr3 ecu, hasport wiring kit, hasport mounts
approx stock dist, timing.
walbro 255 pump
12:1 vortech fmu
sohc greddy kit, 15g, dsm smic running stock 5.5 psi
msd sport compact ignition
ngk 7 series gapped to .35
msd 8mm wires
2 1/2 inch exhaust, no cat
155whp 138 ft. lbs of torque
my a/f went from about 4k 12.1 straight to 10.1 all the way to redline. i was boosting 5.5 , and i lost almost two pounds of boost by redline.
the future holds a mbc, a safc 2 fuel controller, big injectors, and more boost. but for now i want to see if i could do anything to pull any power out? do i want to play with timing? off the distributor? or what? i dont know what else i can do. before i spend big bucks on this car.
Old Jan 19, 2004 | 08:31 AM
dc2b18c1gsr's Avatar
Default Re: my dissapointing dyno numbers. b16a turbo (stolencrx)
wwow, that is disappoiinting. i would cry if i were you. my stock gsr makes that.
Old Jan 19, 2004 | 08:36 AM
B18Flip's Avatar
Default Re: my dissapointing dyno numbers. b16a turbo (dc2b18c1gsr)
did you do a compression test??
Old Jan 19, 2004 | 08:44 AM
Default Re: my dissapointing dyno numbers. b16a turbo (B18Flip)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18Flip &raquo;</TD></TR><TR><TD CLASS="quote">did you do a compression test??</TD></TR></TABLE>
nope, i need to.
Old Jan 19, 2004 | 08:45 AM
quikB18B's Avatar
Yeah i would start the with the base of it all, find out if your motor is 100%, and then go from there.
Old Jan 19, 2004 | 08:47 AM
Rob Dizzle's Avatar
most likely something is wrong wiht the motor or the fuel or timing is way off
its prolly not because you need more boost
you could have bent valves or something
Old Jan 19, 2004 | 08:51 AM
Default Re: my dissapointing dyno numbers. b16a turbo (Bob-DC2)
i might just have a pressure leak somewhere too.....
Old Jan 19, 2004 | 08:54 AM
COOKIEPUSS's Avatar
I would do a compression test
Post dyno w/ A/F Curve
Close the plugs to .028 (double check this w/ someonelse to be safe)
Check for boost leaks
Old Jan 19, 2004 | 08:58 AM
Default Re: my dissapointing dyno numbers. b16a turbo (COOKIEPUSS)
woont gapping my plugs tighter make me run richer?
im already hitting 10.:1 a/f
Old Jan 19, 2004 | 08:59 AM
BoostedsiR's Avatar
get rid of that bullshit setup get hondata, I hate seeing all these people trying to run SOHC kits on a DOHC get it right, I understand you want things done cheaply but your mani is extremely important to the whole turbo setup and having a weaker sohc mani on there wont help flow and the b 16 really doesnt have the best exhaust flow.
Old Jan 19, 2004 | 09:08 AM
gdrum's Avatar
Default Re: my dissapointing dyno numbers. b16a turbo (BoostedsiR)
get uberdata !!!!
Old Jan 19, 2004 | 09:17 AM
FuriousGeorge's Avatar
Gap your plugs to .030
What disc are you using in your FMU? Maybe a 12:1 is too rich for you, switch it out for an 8:1
Old Jan 19, 2004 | 09:18 AM
CRX T-Si's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoostedsiR &raquo;</TD></TR><TR><TD CLASS="quote">get rid of that bullshit setup get hondata, I hate seeing all these people trying to run SOHC kits on a DOHC get it right, I understand you want things done cheaply but your mani is extremely important to the whole turbo setup and having a weaker sohc mani <U></U>on there wont help flow and the b 16 really doesnt have the best exhaust flow.</TD></TR></TABLE>
I don't think you can put a SOHC manifold on a B16.
Anyways, I have a B16 turbo in my CRX and it was running on 3 cylinder ($3 at 90psi) and it still ran hard as hell. I am using the VAFC Hack with MSD BTM.
Do you smell oil when you drive??? do you see white smoke coming out of your valve cover?? If yes then do the compression check. Let us know.
Your numbers are bad but don't be sad, at least your car looks good. Unlike my rust bucket.
Oh yeah you can send your ecu to Cheetah to get it done cause I will be sending him mine soon when I have some extra flow.
Blackack26's Avatar
Default Re: my dissapointing dyno numbers. b16a turbo (gdrum)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gdrum &raquo;</TD></TR><TR><TD CLASS="quote">get uberdata !!!!</TD></TR></TABLE>
uberdata is not for everyone, you have to realize that
Old Jan 19, 2004 | 09:31 AM
it is a sohc greddy manifold
anyways.. heres what i got as for as answers to my orginal question, other than the negitive comments.....
try changing gaps on plugs
check for boost leaks, and vacuum leaks
any other postive help i can get? thanks guys
Old Jan 19, 2004 | 09:43 AM
Joseph Davis's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stolencrx &raquo;</TD></TR><TR><TD CLASS="quote">i might just have a pressure leak somewhere too.....
That's what your boost taper makes me think. Small boost leaks lead to the compressor overspooling and you heat the charge noticeably, making it much less dense. It also kills turbo life... get on it and fix it pls. Pressure check all components, and don't use a screwdriver to tighten fittings - that is pointless - use a socket and make *sure* they are tight.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blackack26 &raquo;</TD></TR><TR><TD CLASS="quote">
uberdata is not for everyone, you have to realize that </TD></TR></TABLE>
You're entirely right. If you'd rather spend a lot more money and a lot more effort to have little to no control of your fuel and ignition, then Uberdata is not for you. Well you can spend even more money than that and get Hyundaidata/EMS that the same person in this example couldn't use anyway, which would perform just as well as cheap old Uberdata.
This isn't an OBD1 application, but allow me to go a little further OT on the subject... FYI, in this case I'd suggest an OBD0 90-91 PS9 or 90-91 PR4 automagic ECU and some turboEDIT boost/one wire VTEC code... you could probably sell the PR3 for what it takes to buy said ECU and chip burner.
Buy a chip burner and roll the software and stuffs into your tuner... if they can fiddle a complex machine like an EMS or have any Hyundaidata experience, they can tune with Uberdata. JDogg, one of the stupider people I know (he's a factory trained EMS tuner, and Prelude/Accord fanboy, therefore completely ignorant), got 198 whp out of a stock H22 with generic filter on a stick and a butchered beat up rig job header on one of his first tuning runs with Uberdata. He had a little tuning experience using other standalones in the past, but as I said he's an idiot so any tuner you pull out of your hat can do at least as well or better.
:&gt;
Old Jan 19, 2004 | 09:48 AM
CRX T-Si's Avatar
Default Re: (stolencrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stolencrx &raquo;</TD></TR><TR><TD CLASS="quote">it is a sohc greddy manifold</TD></TR></TABLE>
Damn I just learn something New myself today.
Get rid of that, it has no place in a DOHC B16.
Old Jan 19, 2004 | 10:01 AM
Ri5e's Avatar
Default Re: (CRX T-Si)
Thats a really now number. My friends RSX makes 185 WHP with just intake
Definetly do a compression check
Old Jan 19, 2004 | 11:20 AM
DaNish's Avatar
Default Re: (BG Boost)
what did you expect with that shitty turbo and weak amount of boost?
Old Jan 19, 2004 | 11:23 AM
AB16A2T's Avatar
Default Re: (X DaNish X)
I make like 143.8hp 103.7tq on my almost completely stock B16. All I have is an intake, and exhaust. Something isn't right, do a compression test. Start from there. Should be making a lot more power.
EDIT: Torque is a lot more than a stock B16 though.
Old Jan 19, 2004 | 11:35 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by X DaNish X &raquo;</TD></TR><TR><TD CLASS="quote">what did you expect with that shitty turbo and weak amount of boost?</TD></TR></TABLE>
Spoken like a years-long subscriber to Stupid Street.
I've seen 200 ft/lbs by 3000 rpm and 180 whp by 5000 rpm on LS at 5.5 psig, with that shitty turbo and that weak amount of boost. If anything, the cfm consumed by a B16 @ 5.5 psig, all other things being the same, should net something fairly decent.
It's also in a CRX, it doesn't take much.
Old Jan 19, 2004 | 11:37 AM
BoneStckCivic's Avatar
Who did your swap and work on the car??? Where u from ??? Let me know
Old Jan 19, 2004 | 11:45 AM
SiRkid's Avatar
Default Re: (BoneStckCivic)
15g
Old Jan 19, 2004 | 12:18 PM
Mr. Softee's Avatar
Default Re: (SiRkid)
check ignition / cam timing. repeat dyno.
Old Jan 19, 2004 | 12:25 PM
TurboJesse
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoostedsiR &raquo;</TD></TR><TR><TD CLASS="quote">get rid of that bullshit setup get hondata, I hate seeing all these people trying to run SOHC kits on a DOHC get it right, I understand you want things done cheaply but your mani is extremely important to the whole turbo setup and having a weaker sohc mani on there wont help flow and the b 16 really doesnt have the best exhaust flow.</TD></TR></TABLE>
explain a "weaker Sohc Mani" ....I dont' think his problem is the Mani, the turbo..or the exhaust flow of a b16a...there is somehting with his motor or tuning (lack of).. Ive seen similar numbers with the same kit on a d16 @ the same boost. Something isn't right, but he doesn't need a blinging manifold or oversized turbo to fix it
