rear sway bar on DX CRX
Old Oct 1, 2001 | 03:26 PM
wuhungsixxx's Avatar
New User
Default rear sway bar on DX CRX
iv heard that DX CRX(gen2) dont have rear sway bars...now i wanna put on aftermarket swaybars onthe car...to they already have the holes in em so i canbolt em up or do i need pieces from the SI for them to work??...thanks...
Old Oct 1, 2001 | 03:34 PM
4wsB21a's Avatar
New User
Default Re: rear sway bar on DX CRX (wuhungsixxx)
i have been told that the integra swaybar in the rear can bolt into the crx, but am not sure if the crx already has the holes or not. most likely not, since they don't come with them. if you can get a swaybar out of an integra for cheaper, then you can also use that, just fyi.
i also have a dx, so if you get it to work let me know, and if i get one and put it in i will let you know, if you haven't done so already.
[Modified by crxplus, 12:35 AM 10/2/2001]
Old Oct 1, 2001 | 03:58 PM
Spaceballsthelunchbox's Avatar
No Big Whoop
The DX has the holes to attach the brackets, but there are no nuts inside
so you cannot thread a bolt there.
The Integra rear sway bar is a direct bolt on.
You might want to get the Suspension techniques rear sway bar which comes complete with brackets and bushings.
Old Oct 1, 2001 | 04:02 PM
New User
Default Re: rear sway bar on DX CRX (Spaceball the lunch box)
yea thats what i was planning to go with ST or Addco...so r u guys saying to go with the aftermarket version for the 90-93 teg(DA) or shoudl i get the kit for the SI CRX?
Old Oct 1, 2001 | 05:09 PM
Overkll's Avatar
Go with the ST for the Civic/CRX, it's adjustable to suit your needs. Full stiff will wrap you around a pole (oversteer). HTH Kerry
Old Oct 1, 2001 | 06:45 PM
fixhondas's Avatar
Default Re: rear sway bar on DX CRX (Overkll)
I put ST on my DX- For the rear- I drilled a hole big enough to get my finger in into the side of the body next to where the holes for the sway bar brackets should be. Then I put nuts in there and bolted the brackets up. I then sealed the hole- no problem.
Old Oct 2, 2001 | 04:28 PM
WWDTrackRacer's Avatar
New User
Default What about welding the Honda brackets?
Anyone ever thought about welding the Honda brackets on
a non-equipped chassis?
- Jeffrey
Old Oct 2, 2001 | 04:40 PM
Stinkalope's Avatar
New User
Default Re: What about welding the Honda brackets? (WWDTrackRacer)
That is a good idea. I have acquired a rear sway bar with brackets for free in a package deal. Has anyone tried to weld them on? It would be stronger anyway.
Turbo Dan
Oct 24, 2005 02:18 PM
BIG RICH
Sep 23, 2003 03:20 PM
wronghand
May 4, 2002 08:42 PM
TheShocker
Oct 16, 2001 10:39 AM
Jul 19, 2001 04:37 AM
