idle problem for b16a
aiite i know this issue comes up alot , i read almost all of the post on this aswell, my problem is that when my car is at a cold start it idles about 1900 rpm when its normal temp its about 1100 n goes up n down to about 1300, i changed out my fast idle valve, idle air control valve, adjusted my tps, check all vaccums, try to reset the the idle srew, what else could it be?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mysiqu »</TD></TR><TR><TD CLASS="quote">aiite i know this issue comes up alot , i read almost all of the post on this aswell, my problem is that when my car is at a cold start it idles about 1900 rpm when its normal temp its about 1100 n goes up n down to about 1300, i changed out my fast idle valve, idle air control valve, adjusted my tps, check all vaccums, try to reset the the idle srew, what else could it be?</TD></TR></TABLE>
my b16 does the exact same thing. Idle at about 1900 rpm at cold start and on occasion the idel fluctuates from 1100 rpm to 1300 rpm. Im guessing this is a common problem. hehe
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mysiqu »</TD></TR><TR><TD CLASS="quote"> i changed out my fast idle valve, idle air control valve, adjusted my tps, check all vaccums, try to reset the the idle srew, what else could it be?</TD></TR></TABLE>
Damn, thats everything I was about to say. Tried bleeding the coolant then resetting the ECU?
