Tach Accuracy?
Old Jan 18, 2004 | 08:45 PM
jfoster's Avatar
Default Tach Accuracy?
So I was doing some searching about revlimits for GSRs and ITRs trying to decide what to do for my ITR cams and springs and several of the posts that I read in which ITR owners replied they said that their rev limit was 8,600rpms but they sometimes shift at 8,800+ due to the stock tach being off at higher rpms. Is this true?
If so can something be done about it? Like something other than the giant rice monster $200 dash mounted tach.
By the way my car is a GSR.
Old Jan 18, 2004 | 09:39 PM
MEANB18's Avatar
Default Re: Tach Accuracy? (jfoster)
yeah, tachs and even speedos are incorrect when they get higher in the rpm/mph range if I remember right. I don't know what you could do unless you had like a digital dash, I could be wrong though.
Old Jan 19, 2004 | 08:51 AM
jfoster's Avatar
Anyone dealt with this problem?
Old Jan 19, 2004 | 11:50 AM
vtecb20coupe's Avatar
B A N N E D
not much you can do but invest in an aftermarket tach, like autometer. and no, you don't have to get the 5".
Old Jan 19, 2004 | 03:02 PM
jfoster's Avatar
Default Re: Tach Accuracy? (vtecb20coupe)
I guess I am just going to get a programable shift light. What I would really like is a high quality replacement for the stock tach. Same look but perfect accuracy.
Old Jan 19, 2004 | 03:36 PM
MrTodd's Avatar
Perfect accuracy?
V-AFC. It reads the digital output provided by the ignitor to give you the exact RPM reading, basically it see's what the ECU see's. I think that's as accurate as you'll get. There might be some other digital RPM displays out there, not sure where to find one though...
Old Jan 19, 2004 | 03:45 PM
jfoster's Avatar
Default Re: Tach Accuracy? (MrTodd)
Yeah someone mentioned that on another forum but then said that it would be hard to read the display. I think an analog style tach would be easier to read, at least while shifting.
Old Jan 19, 2004 | 03:56 PM
MrTodd's Avatar
Yeah, it really depends on where you mount it. Personally, I don't have mine mounted anywhere near the guage cluster because I don't want theives to notice it, so it's pretty hard to look at the RPM's while I'm driving... If you're creative enough, you could find a place to mount it so it's very easy to see. The V-AFC has settings to where you can have it ONLY disply the RPM in big numbers or a guage style picture. It's pretty cool, I like mine.
I think A'pexi has a turbo timer that shows the RPM's as well? You could mount that on top of the steering column maybe...
Old Jan 19, 2004 | 05:49 PM
machine4321's Avatar
i just got my apexi tach and i love it ...my accord tach is up too 500 rpm off at times ...even more over 6000
Old Jan 19, 2004 | 05:56 PM
jfoster's Avatar
Default Re: (machine4321)
I was thinking about getting a VAFC2 anyway. Does the VAFC (1or2) have a shift light setting? Or just a tach mode? What makes a VAFC2 better than the VAFC?
SFlCrx
Sep 12, 2006 03:46 PM
JuggerNuts
Jun 18, 2006 07:35 PM
alfaaay
Feb 13, 2004 01:08 PM
FusionITR
Feb 28, 2002 07:52 PM
