axles..are the gsr and ls..the same diameter? thanks
Old Oct 1, 2001 | 02:29 PM
ILOVEGIRLS's Avatar
Default axles..are the gsr and ls..the same diameter? thanks
and the answer is..?
Old Oct 1, 2001 | 04:05 PM
JimmieD's Avatar
Default Re: axles..are the gsr and ls..the same diameter? thanks (ILOVEGIRLS)
i read somewhere that type r axles are thicker but have no proof. sorry i cant be of more help.
Old Oct 1, 2001 | 05:06 PM
IN VTEC's Avatar
eyyaaahh...sure, why not.
Old Oct 1, 2001 | 05:09 PM
ILOVEGIRLS's Avatar
Default Re: axles..are the gsr and ls..the same diameter? thanks (IN VTEC)
anyone else? thanks
Old Oct 1, 2001 | 05:57 PM
Rain_man's Avatar
New User
I am pretty sure they are the same, because when I ordered a set of raxles, they didn't ask me what kind of Integra I had. Plus if you look at http://www.carparts.com they don't differentiate between gsr and ls.
Old Oct 1, 2001 | 07:57 PM
RacingE_Teg's Avatar
Default Re: axles..are the gsr and ls..the same diameter? thanks (Ein)
If I'm not mistaken, all B-series axles are the same.
Old Oct 1, 2001 | 10:40 PM
ILOVEGIRLS's Avatar
Default Re: axles..are the gsr and ls..the same diameter? thanks (RacingE_Teg)
thanks
Old Oct 1, 2001 | 11:03 PM
InfamousRS's Avatar
whatr are raxles??? are they after market axles that are strponger than stock??? if so where do you get them and about how much are they?
Old Oct 1, 2001 | 11:14 PM
dustin's Avatar
ABS and non-ABS axles are different.
Dustin
Old Oct 1, 2001 | 11:41 PM
B18C-EJ1
Guest
Posts: n/a
Default Re: axles..are the gsr and ls..the same diameter? thanks (dustin)
ABS axles just have the ring on the outer edge for the sensor.
The only different axles are from the 98 SpecR, they use a different hub.
89-93 are different from 94+
Otherwise all b-series axles are the same
Old Oct 3, 2001 | 11:05 PM
ILOVEGIRLS's Avatar
Default Re: axles..are the gsr and ls..the same diameter? thanks (B18C-EJ1)
thanks..
DC206R
Mar 27, 2011 06:55 AM
turbotegy10
May 20, 2010 05:55 PM
bzyq2001
Jul 4, 2008 04:25 PM
slow_db7
Apr 11, 2008 12:37 AM
NsX_CrX
Feb 5, 2007 07:50 AM
