ODD PROBLEM
Old Jan 18, 2004 | 05:37 PM
ad7hbacc's Avatar
Default ODD PROBLEM
i slid my 87 accord into a concrete corner the other day and it was still driveable. no rubbing it ran fine nothin on the engine damaged at all.....jus my bumper and driver's side headlight and fender were damaged....ran fine all day long and then the next day it was totally dead...doesnt even crank....o and the battery is good...any thoughts anyone?????please?
Old Jan 18, 2004 | 06:35 PM
jwogen1's Avatar
Default Re: ODD PROBLEM (ad7hbacc)
did you check under the hood and see if maybe something was knocked loose that may have disconnected after a bit of driving? good starting point, but may be a shot in the dark....
Old Jan 18, 2004 | 07:38 PM
RotaryBzzzz's Avatar
i'm guessing your not even getting dash lights.
A 87 accord in North Dakota has seen some pretty hard weather. I'd suspect a marginal battery cable ground finally gave up the ghost. Check the attachment of the battery negative terminal to the body - wiggle (gently) everything with the key turned to on.
Danny Jay
Jan 12, 2015 08:58 AM
NIKLASAL
Feb 29, 2012 02:58 PM
wood181
Apr 15, 2008 06:59 PM
mandalorianjedi
Dec 19, 2007 11:46 PM
