sponsors needed. b18 turbo civic si
i have a 1999 civic blue si that i had built from scratch. The motor is a gsr bottom end with darton solid deck sleeves 84mm, cp pistons 10.5.1, crower rods, crower crank, moroso pan, toda oil pump, b16 head with full race port and polish 1mm oversize valves, skunk 2 valve springs, skunk 2 retainers and some b16 cams. The turbo is a turbonetics t 61 with a sfp manifols and tial 38mm waste gate.
The fuel system is a aeromotive a2000 pump with -10 lines and russel fittings. The rear suspension is ground control struts and springs and the front suspension is tokiko bues with gound control coil overs. The engine is controlled by a aem ems.
I am currently installing a kaaz lsd and drive shaft shop axles stage 5. the traction is gained by some 26" slicks mounted on a set of bogart wheels. The car will be producing some were around 600 hp when tuned. I will be running most of the events along the east coast and attending most of the car shows along the east coast. any questions please email me at tedoe123@aol.com
the best way to get sponsors is to take some nice pics of your car, and send them to companies telling them what events you plan on doing, what you have done to your car. What you want out of there end? What you will do for them if sponsored and so on.
9SECQTR
Jan 30, 2004 04:08 PM
