swaybar + 3" exhaust = ???
I have been looking into replacing my rear sway bar, but I'm also about to get a 3" exhaust. I dunno wether or not to get the comptech combo sway bar or the ITR 22mm sway bar... Does anyone know if the would be any fitment issues?
i have a solid 21mm rear bar, and a 3" exhaust on my gsr 4-door with no problems. just make sure you reinforce the mounting points on the chassis for the bar. mine has riped off twice now.
I have heard that using the ITR sway bar on non-ITR LCA can be an issue? I'm leaning towards the comptech sway combo, but it looks like the clearance on the combo might be too tight for what I'm looking to do. People are saying that if you put a couple of washers between the ITR sway bar and the LCA that the angle problem will be solved, but that solution seems a bit iffy for me.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr206 »</TD></TR><TR><TD CLASS="quote">i have the itr with 3inch ., no fitment probs here</TD></TR></TABLE>
Same here, no problems
I have pics of the exhaust getting fitted. I know the angle had to be changed right before the sway bar and the hangers were modded to accomadate. I will get the pics up when i get home, i know i have them.
5Point7Liter
Suspension & Brakes
11
May 2, 2007 10:16 AM
