weird noise
Alright, heres my problem, i get this weird buzzing sound that seems like its coming from where the airbag is. It usually comes when i down shift to slow down and rpms go to about mid 5k or when im on the gas. and when i push the clutch in, it stops. this usually happens at 3rd, 4th and sometimes 5th gear. Its not vtec because i know what that sounds like. and sometimes i can hear it as well as the vtec. anybody got any clues or info on this ****? its really annoying.
stop downshifting to slow your car down .. unless you want to replace your clutch every 6 months..it doesnt do it when you dont downshift .. from what i can see from what you typed
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ShowTymers619 »</TD></TR><TR><TD CLASS="quote">stop downshifting to slow your car down .. unless you want to replace your clutch every 6 months..it doesnt do it when you dont downshift .. from what i can see from what you typed</TD></TR></TABLE>
You're wrong cause he typed it happens when he accelerates or is steady on the throttle also...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by succdeez »</TD></TR><TR><TD CLASS="quote">It usually comes when i down shift to slow down and rpms go to about mid 5k or when im on the gas.</TD></TR></TABLE>
How does you telling him to stop driving the way he drives help his problem in anyway?
Do you have a front strut tower brace? If so, you might want to check the clearance all around it. I use to have a strong vibration before i bent the power steering hose mounting bracket on the valve cover when i had my Mugen FSTB.
Edit: You need to describe your problem with more detail if you want help because we cannot actually hear the problem.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sjracer »</TD></TR><TR><TD CLASS="quote">
because we cannot actually hear the problem.</TD></TR></TABLE>
yeh i do have one, its a DCsports titanium.
The buzzing sound stops at around 6k rpm tho, do you think it could be something wrong with the block or one of the valve or cylinders?
Thanks for your responses.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by succdeez »</TD></TR><TR><TD CLASS="quote">Alright, heres my problem, i get this weird buzzing sound that seems like its coming from where the airbag is. It usually comes when i down shift to slow down and rpms go to about mid 5k or when im on the gas. and when i push the clutch in, it stops. this usually happens at 3rd, 4th and sometimes 5th gear. Its not vtec because i know what that sounds like. and sometimes i can hear it as well as the vtec. anybody got any clues or info on this ****? its really annoying.</TD></TR></TABLE>
I had something similar to this, I found the two bolts that hold the plastic cover over the fuel injectors were loose.
Good Luck
Good Luck
yeh i have an AEM Cai but the sound seems like its coming from under the airbag. i know that some DC2s have a problem with the firewall rattling at high rpms, have you guys heard of this?
lilo_goki
Mar 18, 2008 07:46 PM
