Plugs, cap and rotor - service life?
Old Oct 1, 2001 | 11:16 AM
Splat's Avatar
Collector-o-Guns and Drinker
Default Plugs, cap and rotor - service life?
What is the typical replacement interval for spark plugs, dist. cap and rotor on Type R's? Wondering if I need to do some winter maintenance on my car. Just under 24k miles, went from daily driver to weekends only a few months back.
Also, what is the torque spec for the spark plugs? Going to check mine tonite.
Old Oct 1, 2001 | 01:12 PM
Mike K's Avatar
Default Re: Plugs, cap and rotor - service life? (itr009)
Good idea to replace the rotor once or twice a year. Cap can usually go til 30k miles, if not more. As far as plugs, Use your own discretion. I replace my plugs and distributor rotor at every other oil change, but then again, OEM parts for my own car are nicely priced due to the fact that I am an employee for Acura.
Spark plug torque? WTF? I don't think I have ever seen someone do that. If you can't get it by feel, then you need to put the wrenches down now.
Old Oct 1, 2001 | 01:35 PM
Splat's Avatar
Default Re: Plugs, cap and rotor - service life? (Mike K)
Jus' checking!! I'm used to iron heads (see the rest of the fleet down below - IE the Scout!)
[Modified by itr009, 5:36 PM 10/1/2001]
Old Oct 1, 2001 | 02:26 PM
STOLEN - ITR 98-0652's Avatar
Dollar get's you a nickel there is a spec for that in Helms.
Your replacement interval is pretty aggressive - I like it! Spending money on parts is half the fun!
Old Oct 1, 2001 | 04:02 PM
RedRacer's Avatar
New User
Default Re: Plugs, cap and rotor - service life? (ITR 98-0652)
Torque specs on my B16a are for 13 lb. ft. (Got that out of my owners manual) Not sure if that is the same for your car. But better to be safe than sorry when working with aluminum. I believe when it comes to my aluminum motor you should torque everything to be safe. Won't be so fun when you strip out a thread.
Old Oct 1, 2001 | 04:07 PM
Dipshit Dan's Avatar
Default Re: Plugs, cap and rotor - service life? (RedRacer)
I change my fuel filter, cap, and rotor at 30,000 miles max. Plugs I change every 60,000 miles but check every so often just to see how the mixture is.
Old Oct 1, 2001 | 05:12 PM
digitalspice's Avatar
Banned
Default Re: Plugs, cap and rotor - service life? (God)
Integra spark plug torque specs are 13 lbf.ft .
Kokxxy
Aug 22, 2015 04:01 PM
HDkidd
Jan 3, 2008 09:21 AM
crazyguy
Aug 15, 2007 07:29 AM
B_Love
Jul 7, 2005 09:15 PM
Seedc2
Oct 25, 2001 06:59 PM
